Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
  • 33 Answers
Sounds like a flame recification fault change flame sensor or thermal couple and get unit serviced
Posted on Jan 17, 2010
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot comes on but no gas flow.
Hello. you need to replace the thermocouple which is a safety device that turns the gas on and off. Joe
please rate my answer as very helpful. Thanks.
May 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Coversion to LP Gas
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Heating & Cooling Logo
123 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
