Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley 2000 FXST blimker connector removal without tearing it up
    Genius:
  • 2,028 Answers
If stuck, use a penetrating oil overnight, but I wouldn't worry about tearing it up. If you do, just clip it off, go to any auto parts store, buy a new connector, and soldier or crimp it on in place of the old.
Posted on Aug 06, 2008
Hi i have a 2000 fxst harley i put new starter in my bike,than i couldnt get it started so i put new coil and plug wire it run good for 6 or 7 mile,now front plug has no spark.
If the motor was running ok before you changed the starter motor you must have damaged something. Changing a starter motor on a softail harley involves removing the oil tank and wiring. You must have damaged something while doing this. Logic dictates this. Check everything that you touched or moved.
Sep 26, 2014 | 2000 Harley Davidson FXST Softail Standard
What are the torque specs for the derby bolts on hd fxst
84 - 108 in/lbs. Do NOT use loktite and do not overtighten otherwise you will have dificulty in removing these later on. These are not structural bolts, simply cover bolts. For those without a torque wrench, a 'snug' fit will suffice.
Jun 29, 2014 | 2000 Harley Davidson FXST Softail Standard
2000 Harley Davidson FXST Softail Standard rear wheel replacement
Hi Anonymous, the rim size is T16x3.00D and the tire is MU85B16 77H Good luck
Feb 17, 2014 | 2000 Harley Davidson FXST Softail Standard
Changing primary fluid for 2000 fxst
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
UPDATED how to chang the primary fluid on harley softail
Apr 09, 2013 | 2000 Harley Davidson FXST Softail Standard
Code d01clr
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Mar 31, 2013 | 2000 Harley Davidson FXST Softail Standard
Transmission oil change in 2000 Harley Davidson fxst
UPDATED how to change the transmission fluid on harley davidson softail
Aug 29, 2012 | 2000 Harley Davidson FXST Softail Standard
My turn signals and brake light won't work? It's a
Hi Hd84softail, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below: Harley Davidson Wiring Diagrams and Schematics
Apr 30, 2012 | 2000 Harley Davidson FXST Softail Standard
2000 FXST HARLEY engine light blinks on and off,speedo drops off while running, engine does not stop running,also notice that blinker stays on
Hi Nofkbed, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below: Harley Davidson Wiring Diagrams and Schematics Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jun 30, 2010 | 2000 Harley Davidson FXST Softail Standard
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
