Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Hunter model 27576 (Canada) remote dropped
My remote attached to the wall or hand held was dropped-it stopped working, Home Depot replaced the remote and battery- As I have two identical fans in the adjacent rooms I wish to set each differently.
I cannot find the small ?diodes? to set on the fan the same as in the remote (4321) Can anyone help this girl out ?
  • nylram Aug 08, 2008
    thanks to everyone fan working now
  • 417 Answers
up above the fan near the ceiling theres a cover or canopy that has to come off , and theyre inside there, and they have to be set the same as the remote or it wont work.
good luck
J
Posted on Aug 07, 2008
How do I replace pull chain on old hunter fan. No replacement available Home Depot gave generic switch. I don't know what wire color goes in switch L 1 2 3 Wire colors are red black blue
If that's a two speed hunter, you have the wrong switch. You need to get a two-speed switch. This switch comes with the wires attached. Do you have the fan model?
Mar 15, 2015 | Hunter Dryers
Remote control B-542
Peter, Home Depot carries replacement ceiling fan remotes.
Check the attached links,remote and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Hunter Ceiling Fan Remote Control Replacement Light Fan Speed...
Hampton Bay Ceiling Fan Remote Control 70830 The Home Depot
Jan 28, 2013 | Dryers
The remote was dropped and now the fan does not work. It is not an easy task to get to the fan to replace since the ceiling is 18 ft high. We were sent a new remote and told it would work, but it does...
The remote has to be programmed to match the existing fan's receiver code. The programming information should have come with the hand held remote. If it didn't, contact whomever you purchased it from.
Jul 20, 2011 | Hunter Heating & Cooling
I have a hampton bay remote that just stopped working. I have installed new batteries, have checked the code with another remote so I know the problem isn't the fan. The light on the remote does not...
If the light on the remote is not lighting when you push a button, check the batteries to make sure they are in the proper position. If one is turned the wrong way, the hand held will not work. You may also want to check the replacement batteries to make sure they are fully charged. If all this fails to solve the problem, you will need replace the hand held remote. Since Hampton Bay Fans are a house brand for Home Depot, they stock and sell replacement hand held remote controls.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Hampton Bay Heating & Cooling
Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
Aug 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Remote not working fan...
You can get them a Home Depot. You may have to buy the receiver and the remote together.
May 25, 2009 | Hunter Ceiling Fan Remote Receiver...
Can a remote control be installed on the Huntington III?
Yes you can operate them with two styles of remotes: either the remote wall switch, or a hand held remote. Both require the receiver to be mounted above the top of the fan in the base it is wired to. The receiver has wires on both sides; the one side wires directly to the house wires, and the other goes to the fan and light. They are both sold at Home Depot and Lowes. The ones at Home Depot also include the set made by the fan manufacturer.
Feb 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
207 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
