Question about GE Microwave Ovens
I cooked a frozen breakfast in my microwave this morning, it took 3 minutes, then it signaled me it was done and stopped. I took it out of my microwave and shut the door and when I did that I started to run again. The light was on, although I didn't set a time to cook. I tried to push the canel sensor and that didn't stop it. I unplugged it from the outlet and plugged it back in and it started running again (although it is not heating while it is doing this). All the sensors seem to work except for the start and cancel sensors. I have only had this microwave for one month. The model I have is a Profile PVM1870SM1SS
  • GE Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Doorswitch or mount trouble can be caused by slamming the door or byopening the door while it's cooking without hitting the Stop pad first.
Thereare plastic mounts inside the microwave which hold the door switchesand onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimesit's a broken tab on the switch holder, allowing the switch to rotatejust out of position. Other times, it's a broken tab on the switchholder, allowing the switch to rotate just out of position. This tabcan be hard to see, since it is under the bottom edge of the switch.
Ifyou or someone you know decide to look into it, we have criticalinformation on safety, disassembly and door switches at our site, andour link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
How do I cook a frozen 2 lb meat lasagna in my Jetstream oven?
I would start with a slow 250 oven for about 45 minutes. If the lasagna is thawed by then kick the oven up to 350 for another 30 to 45 minutes. Test temperature with a thermometer or knife blade to see if done.
Sep 08, 2017 | Nesco American Harvest Jet Stream Oven
Microwaves and how they work. ­T­he microwave oven is one of the...
--> ­T­he microwave oven is one of the great inventions of the 20th century -- millions of homes in America have one. Just think about how many times you use a microwave every day:
­You're running late for work, so there's no time to fix breakfast at home. On your way to the office, you stop to gas up your car. Inside the quickie-mart, you grab a frozen breakfast burrito and pop it in the microwave on the counter. Later that day, you have to work through lunch. By 3:00 p.m., you're starving, so you grab a snack-pa­ck of microwaveable popcorn from the vending machine and pop that in the break-room microwave. That night, after a really long day at work, you're simply too tired to grill out, so you dish up last night's lasagna and heat it up in the microwave...
As you can see, microwave ovens are popular because they cook food in an amazingly short amount of time. They are also extremely efficient in their use of electricity because a microwave oven heats only the food -- and nothing else. In this article, we'll discuss the mystery behind the magic of "meals in a minute" with microwave cooking.
­A m­icrowave oven uses microwaves to heat food. Microwaves are radio waves. In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat. Microwaves in this frequency range have another interesting property: they are not absorbed by most plastics, glass or ceramics. Metal reflects microwaves, which is why metal pans do not work well in a microwave oven.
Microwave cooking ­You often hear that microwave ovens cook food "From the inside out." What does that mean? Here's an explanation to help make sense of microwave cooking.
Let's say you want to bake a cake in a conventional oven. Normally you would bake a cake at 350 degrees F or so, but let's say you accidentally set the oven at 600 degrees instead of 350. What is going to happen is that the outside of the cake will burn before the inside even gets warm. In a conventional oven, the heat has to migrate (by conduction) from the outside of the food toward the middle. You also have dry, hot air on the outside of the food evaporating moisture. So the outside can be crispy and brown (for example, bread forms a crust) while the inside is moist.
In microwave cooking, the radio waves penetrate the food and excite water and fat molecules pretty much evenly throughout the food. No heat has to migrate toward the interior by conduction. There is heat everywhere all at once because the molecules are all excited together. There are limits, of course. Radio waves penetrate unevenly in thick pieces of food (they don't make it all the way to the middle), and there are also "hot spots" caused by wave interference, but you get the idea. The whole heating process is different because you are "exciting atoms" rather than "conducting heat."
In a microwave oven, the air in the oven is at room temperature, so there is no way to form a crust. That is why microwavable pastries sometimes come with a little sleeve made out of foil and cardboard. You put the food in the sleeve and then microwave it. The sleeve reacts to microwave energy by becoming very hot. This exterior heat lets the crust become crispy as it would in a conventional oven.
on May 07, 2010 | Microwave Ovens
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
No microwave problem. I have a micro 21 by raytheon pan. Please tell me how much water, vegetables and time to cook them. I don't have a instruction book.
I found an instruction booklet. For most veggies (1/2 lb) steam for 10 minutes using 3/4 cup water. Add 5 minutes steaming time for frozen. 1 whole cauliflower is 15 minutes & 1 cup water
Dec 21, 2010 | Microwave Ovens
Emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
Jun 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Does not cook even . put 2 items in cooker one well done other one half,
were both items the same density? Was one maybe thawed more that the other? A microwave cooks by rapidly heating the water molecules within the product that you are heating. If you heat two of the same product, it should cook them both evenly, however say you put in a frozen hamburger and a thawed hamburger, the frozen one will only begin to defrost while the thawed one will actually cook
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
GE Spacesaver Microwave Oven JVM1640BB
unplug the unit and if you can open the housing and slowly remove the ribbon cable of the touchpad console to the main board. put it back after 5 minutes and try it. let me know what happen.
Feb 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
