Question about Video Game Consoles & Games
Disc scratched badly and it isn't working - Video Game Consoles & Games
Try This:Use a dry,or lightly damp,tissue. Rub and dab at each scratch carefully, and, do not do so in Circular motion
Posted on Jul 06, 2008
How do i fix a scratch on my game?
You could try buying the disc repair solution from Game Stop I think it's about $6.99
My friend bought it and it worked just fine, as long as the scratch isn't too deep it should work.
Jul 10, 2012 | Microsoft Xbox 360 Elite Console - Black
Tip
How to Fix a Scratched CD
Clean the disc. Even if a CD isn’t actually scratched or scuffed, dust, oil, and other surface contaminants can prevent it from playing properly. Thus cleaning the disc should always be your first move. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+1162261192+0674921071+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google
Fix It Scratch RemoverRepairs Scratches Like Magic! As Seen on TV. Guaranteed.
www.AsSeenOnTvAdvisor.com/FixIt
  • Run warm water over the damaged disc to remove dust.
  • If there is stubborn dirt or grease on the disc, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Any time you rub or wipe a CD, you should do so by starting at or near the center of the disc and rubbing straight outward toward the edge to prevent further scratching.
  • Shake the water off and let the disc air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
  • 2Try to play the disc. Many times a good cleaning is all that is needed. If, however, problems persist after cleaning, try to play the disc in a different CD player. Some players handle scratches better than others; computer CD drives and car stereos tend to be the best.
  • 3Burn a new disc. If you can get the CD to work in one CD player - especially your computer’s - but not in others, try burning a new disc. The CD burner on your computer may be able to read the CD well enough to produce a perfect copy. You may wish to try this even if the CD doesn’t play correctly on the computer.
  • 4Locate the scratch. Actually repairing the disc will be easier if you can figure out where the offending scratch is. Visually inspect the CD’s playing surface for scratches or scuffs. Scratches that run perpendicular to the CD’s spiral - that is, those that run generally from the center to the rim - may
  • on Mar 23, 2010 | Computers & Internet
    How to fix a cd
    That probably means that your disc has been scratched. You can fix this with a disc cleaner, or fix it yourself. To do this, mist the disc with tap water, then slowly dab it off with tissue paper. Repeat this a few times and it should help if the scratch isn't too bad :)
    Jun 11, 2012 | Ubi Soft Naruto: The Broken Bond for Xbox...
    Gamecube cant read my game but can read others
    If the game disc is scratched, you can get it resurfaced at a used game store or movie rental store. If it isn't scratched, the disc might just be defective. It doesn't happen very often, but it's possible.
    Apr 23, 2012 | Nintendo Video Game Consoles & Games
    I put the game fifa 09 in on my wii and when it gets to the starting menu its says this disc is unreadable
    it is possible you have a bad disc/scratched disc or you have a bad laser to read the disc. are you able to play other games on it and is the disc scratched? every disc has a boot up menu it has to go through and if the disc is scratched in the area of the boot mapping then it wont load. thus giving you an error.
    Jul 28, 2011 | Nintendo Fifa 09 for Wii
    Wii could not read disc
    There could be several things wrong. Let's start with the most basic - is the disc inserted correctly? The holographic side needs to be on the left when inserting it. Then, make sure there are no scratches or smudges on the bottom of the disc. A common solution is to wipe it with a cloth or even your shirt if you don't have one handy. Look on the holographic side of the disc to make sure there isn't anything left on it. After cleaning thoroughly, try playing the disc again.
    If you're still having a problem, try restarting the Wii console. However, there's always a possibility that you have a bad disc or, if you're unable to play any games, a bad console.
    Jun 01, 2011 | Nintendo Wii Console
    Tried three CDs, but display shows disc error
    First, try a "hard" reset of the player by physically pulling the power plug from the outlet, waiting at least 30 seconds before plugging it back in.
    After it comes back on, try a non-burned disc you know to be scratch free. If this disc will not work, you have a hardware malfunction. Due to the relatively low prices of consumer electronics, it probably isn't worth fixing, unless it is a high-end brand.
    May 05, 2011 | Audio Players & Recorders
    Cant read disk
    Check to see if there are any scratches on the disc. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. Try a different disc and if this works then the problem is more than likely with that disc and it needs repairing.
    Most Game Discs, DVD’s and CD’s can be fixed quite easily. Some home remedies may help with very light scratches on some of these discs but a professional disc repair service is usually required to repair any discs with more than very light marks or scratches. Discs can normally be repaired back to a virtually new condition.
    For further help on disc repairs, visit:
    www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
    Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
    If you tried some home remedies and they have not worked, try sending the disc off for repair. Contact the site above for advice on repair and shipping.
    Hope this Helps!!!
    May 17, 2010 | Nintendo Wii Console
    Ps3 scratched my game i think
    Go to CDFixers.com. They will professionally refinish your disc for $1.95 and it will look brand new. Good luck!
    May 02, 2010 | Sony Playstation 3 (PS3) Console
    Noisy disc drive - has badly scratched disc in one place.
    if you have your xbox standing up then you want to lay it down, i had this problem if you move your xbox when there is a disk in it, it will make a sound and scratch the disk. the best thing to do is to lay it down on a surface such as a table not the floor, if it still scratches your disks go into the place you got the game from and say your xbox scratched t and wont work anymore, they should give you a new game. if you tried this and it still does it then the best thing to do is to ring up microsoft for repair.
    Jan 21, 2009 | Microsoft Xbox 360 Console
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
