Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox rear projection
Model # 51mp392h\17 and serial # ya1a0509043493
The red converge will not converge nor line up. It will not move left either. all the lights work and we have a picture but with the red out of wack it throws the whole picture out of balance.
  • Philips Master
  • 8,617 Answers
You will need to replace both convergence ics they are both STK392-120 and you will also need four 6.8 ohm 1 watt convergence resistors. You can get replacement ICs and the resistors at the following link and they provide free instaltion instructions with pictures so you can do the repair yourself.Here is the link.
Posted on Jul 06, 2008
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page.
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
My tv is a magnavox and we bought it about 3 years ago and it is now showing like a double picture the color is hazy and pinkish looking the model is 51MP392H/17
The problem of your unit is the convergence. Try to adjust it using the original remote control in the setting menu, then goto the convergence section adjust the red and blue convergence, you should move red and blue UP, DOWN and LEFT or RIGHT, if you cannot move them far enough the convergence IC is defective, replacing this IC will restore the original setting of your tv. This convergence IC is attach to a large aluminum plate it is the heat sink this IC has a marking of STK-#### followed by numbers, remember be careful when replacing this IC you may accidentally tampered or damage the PCB and cause much damage to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards. Try to check this link for the convergence,or.r_gc.r_pw.&biw=798&bih=472&ech=1&psi=JZdtTvDCPIe4iAe72sTABA.1315804977740.3&emsg=NCSR&noj=1&ei=MpdtTpa4OKKSiQfBpcjGBA
Sep 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair, to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Green blured color started at bottom left corner and growing
Based off manufactureing timeline it sounds like you have some capicitors going bad you will need to contact a qualified Service agent for a service call to repair the problem.
Jan 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
51MP392H/17 Red Convergance Problem
you need to replace the two Convergence ICs they are STK392-120 and also about four of the 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions
Jul 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence Ics need to be replaced
Okay that model uses two ICs they are STK392-120 also I would recomend getting at least four of the 6.8 ohm 1watt resistors as that model will usually have a couple of the convergence resistors go open when the ICs fail. You can get replacement ICs at the following link they do provide free instaltion instructions as well as free on line instant messageing with their technicians to help with testing resistors or any other help you need and the support is unlimited and always free for all their customers. Heres the link.
May 28, 2008 | Philips Magnavox 51MP392H Rear Projection...
Wavy lines
I have the same problem with this tv. i took it to a tv repairman, and he told me my convergence circuit board was the problem. the circuit board itself is about $300 and the labor to fix it is another $150. So i never got it fixed, cause it's just too expensive.
Jan 03, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
