Question about Archos Audio Players & Recorders
Its turning on ans archos entertainment your way is showing, but nothing else theres no menu, amd when i plug it into the computer still nothing or charge it
  • 8,596 Answers
Make sure your operating system (XP, Vista, Macintosh, etc) is compatible with the Archos. Make sure you installed the installation CD first, before inserting the player. Restart the computer once before inserting the player. If same result, try a different usb port on the same computer or another computer.
If it still doesn't work, then go to the Archos website and see if a firmware upgrade is available for your particular model.
Posted on Jul 06, 2008
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Archos 605 wifi frozen/bricked
there's a possible error on the disk or the archos storage, - a certain corrupt file could possibly the one making the unit into freeze..
POst back here again
Thank you
May 21, 2008 | Archos 605 WiFi Digital Media Player
Wont install to computer
On the Archos:
In the settings menu from the front screen, set your Archos to 'PC Hard Drive' instead of Windows Media Player.
If it doesn't show as an external hard drive when you plug it into your pc, do this....
On the pc:
Go to Start\run, type diskmgmt.msc and click ok to take you into Disk Management.
Your Archos should show as a drive in here and you can associate your new drive with a drive letter.
If you cannot see your Archos in this windowafter you've set it to 'PC Hard Drive' on the Archos, then you may have a dodgy usb cable.
Hope this helps......
Jul 19, 2010 | Archos 605 WiFi Digital Media Player
When i connect my archos 604 to the computer my computer says Please insert disk into Removable disk (G:)?
Hi, ensure your Archos is already turned on before plugging in the USB cable and select HardDrive Mode on the pop up notice. If this dosn't work, once your Archos is ON and plugged in to your computer, press MENU on your Archos and select USB then HardDrive Mode on the next screen. Hope this helps, Shaz
Oct 31, 2009 | Archos 604 Digital Media Player
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
Mar 20, 2009 | Archos Internet Media Tablet MP3 Player
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Feb 03, 2009 | Archos Internet Media Tablet MP3 Player
Downloading
In the settings menu from the front screen, set your Archos to PC Hard Drive instead of Windows Media Player.
It will then just show as an external drive when you plug it into your pc and you can drag and drop files from the pc.
Dec 26, 2008 | Archos 605 WiFi Digital Media Player
Usb cable for archos 404
Check device manager and verify that it is showing up in there. Also, have you checked My Computer?
Mar 25, 2008 | Archos 404 Digital Media Player
I need help
Once you format your device it wipes out most of the information on your archos including the Firmware. You need to connect your archos to your computer and download the firmware from the main Archos site. Copy the firmware to your device. Diconnect the device from your computer using the safe disconnect feature. When your archos restarts it will either automatically recognize the new firmware and update itself or it will bring up the repair screen. One version of this screen has the options "do nothing", "repair device", or "format". Choose repair device. This will start the update sequence.
The other version of the white screen will say your system is damaged and show the options "done" or "repair device". Again select repair device and the update sequence will start. You may have to do this more than once in a repair session.
I have had to do this to my own device several times so save a copy of the firmware and your plugins on your computer to download back to the device if you have to do this again. Hopefully the next Archos update will take care of these annoying issues
I hope this helps!
Jan 24, 2008 | Archos 605 WiFi Digital Media Player
47 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
