Question about SanDisk Sansa e260 MP3 Player
Sansa e260 it says "Load main image failed Switch to Recovery mode." But how do i switch to recovery mode?
  • 1 more comment
  • freakanature Jul 06, 2008
    I've downloaded the recovery tool and the recovery instructions are not applicable to my sansa player. It's asking me to hold butons my player doesnt have.
    ok I finally got it to switch into recovery mode and i reformatted it (i think)
    thank you very much for your help
  • Anonymous Jul 25, 2008
    Hi. My sansa player got stucked up in recovery mode. Whenever I switch it, it displays "switch to recovery mode" and when I make it hold, it's showing "keypad locked. system shutdown" and the power goes off.
    I have downloaded the sansa recovery mode software from the internet. I don't know how to use it?
    Please help me to get out of this problem.
  • 8,596 Answers
Download the Sansa Recovery Tool from sandisk's website
Posted on Jul 06, 2008
mikethompson
  • 155 Answers
SOURCE: where have SANSA E260's drivers
Update the firmware of the player.
Posted on Oct 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: SanDisk e260
The volume + method listed below is the recovery method - you can somtimes substitute REC for volume +:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
SOURCE: kashif
when i start my sansa e260 that shows a black screen and on that screen a message will apper ( LOAD MAIN IMAGE FAILED SWITCH TO RECOVERY MODE ) please tell me about that problem and what i can solve this problem please tell me a good way to solve this problem. thanks
Posted on Jul 11, 2008
SOURCE: Sansa e260 starting in "Load main image failed Switch to Recovery mode"
well i hvae just have the same problem but look forward to fix this problem
Posted on Oct 16, 2008
  • 102366 Answers
SOURCE: My Sansa E260 says load main image failed switch
http://www.sandisk.com/sandisk-support/driver-download-wizard
Posted on Jul 09, 2010
My sansa e260 dosent read in the computer
well if you are trying to use itunes, then it won't show up. Only ipods or iphones do.
Nov 17, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed SunDisk Sansa e280r rhapsody Refurb
load main image failed Switch to recovery mode e260
Aug 05, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Problems with Sansa e250 + Rockbox
Go to Sandisk's website and download the Sansa Recovery Tool
Jul 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Donwload the Sansa Recovery Tool form Sandisk's website
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
129 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
