Question about Sony Playstation 3 (PS3) Console
Ps3's when i turn my ps3 on it says no signal but the green light is on, i have checked all the wires
  • 43 Answers
How are you connected sony through which the cable? HDMI or scart. If it is connected via HDMI 99% is unfair to cable and me has happened to.
Posted on Jul 07, 2008
Why only left turning signal not blinking only when headlights on? green arrow pointing left seen but not blinking. When headlights off, both turning signals work perfectly,
It sounds as though you have a wiring problem around that particular light/signal.
Check the black earth leads to the light and the signal - it may be nothing more than a 'bad earth' due to corrosion where the earth wire connects to metal.
Check the main power wires, too. It should be an easy fix .. make sure the wires are clean and secure
Apr 16, 2017 | Cars & Trucks
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
2004 Cadillac Deville when you turn on the turn signals all lights including trunk bake strip blink by cutting the green wire on the drivers side tail light plug it stopped and everything appears to work...
Green is usually the left turn signal. it should go to the turn signal switch on the steering column. I would start checking the wires (black) and make sure they all have ground to the body. And if they do I would look at the turn signal switch. All of your lights on the outside of the car go threw the turn signal switch. Head lights, turn, park and brake.
Sep 08, 2011 | 2004 Cadillac Deville
Cant get internet connestion
Are you hard wiring it? if so you may need to reboot your modem then start the ps3 back up. Don't unplug from the computer and connect it directly to your PS3 because the modem still has the computer's ip address and it won't recognize the PS3 until you reboot it. If it's a wireless connection, check to see that when you scan for wireless connection that the green wireless LED is blinking, meaning it's searching for a signal. If it's blinking, then try resetting the modem and the wireless router as well and give it another try. If the green light does not blink, then there might be a harware issue with your PS3. Good luck
Jun 04, 2011 | Sony Playstation 3 (PS3) Console
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
84 honda shadow front running lights replacement: new running lights have different color codes (red, black & back/white)... which wires go to the existing wires which are: orange, orange/white &...
As the wiring on aftermarket signals is not standardized, you will need to determine which wires are ground, running, and turn respectively. If you can disassemble the signal, the ground will be connected to the outside of the socket, and the other two will be running and turn. If you cannot disassemble the signal, or have access to a multimeter, you can determine which wire is ground by checking continuity between the outer socket and wires. Your stock green wire is the ground, and the orange/white is running light. If when you hook the wires up, your running light is brighter than the turn signal, switch the leads.
Hope this helps.
Aug 20, 2010 | 1984 Honda VT 500 C Shadow
REAR BRAKE LIGHTS DO NOT COME ONLY TAP LIGHT IS
Check for power at the turn signal switch. White wire comes from brake switch switch into the turn signal switch. The brake light switch is working because the high mount brake light is working..right? Do the turn signals work ok? if so, then the wiring is OK. The brake signal wires that come out of the turn signal switch are dark green(right) and yellow (left).
Oct 27, 2009 | 2001 GMC Safari
Driver side signals only work when headlights are OFF
What may have happened is either the headlights wiring or the parking lights wiring somewhere along the wiring fused to the left turn signals wiring. Depending on if the turn signals go on when you put the parking lights on or the headlights on.
If the signals come on when you turn on the headlights than you only need to locate the light green wire that comes off the left turn signal harness.
Next follow that wire the entire way back to the firewall looking for another wire fused to that wire as you go.
If there are no signs of this you need to continue looking on the other side of the firewall all the way back to the turn signal and hazard flasher unit which is a black box that connects to a black harness located next to a grey harness behind the knee bolster.
But if the signals come on when you turn on the parking lights than you will also need to check the wiring from the rear left signal and follow that light green wire all the way back to the turn signal and hazard flasher unit.
This should fix your problem, but if not than your problem may lay within the the wiring between the turn signal/hazard switches and the turn signal and hazard flasher unit.
Also you may have a burnt circuit in the junction block. This block is where the light green from the rear left signal and front left signal meet. Don't have a description but if you cannot find it let me know and I will go out to the yard and look myself and let you know.
Apr 22, 2009 | 2004 Dodge Intrepid
Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Apr 11, 2009 | 2006 Ford Expedition
Can't figure out why no power is getting to the right side brake light and turn signal. The other lights work on the tailight. I checked the fuses. brake light switch, and checked the wires for damge.
your wiring may have gotten pinched by crossmember or something else.i would check for power out of the fuse block.there are four wires on the right side coming out of your fuse box with a seperate flat vertical plug,the colors are brown,dark green,yellow and light green.brown is tailight,light green for your backup lights and green and yellow for left and right stoplight/turn signals.use a test light at the plug.
Mar 28, 2009 | 1985 GMC K1500
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
