Question about Soleus KY-34 Portable Air Conditioner
My Unit is running but is saying it is full
Unit monitor is saying full. Do I need to empty something?
Yes you do need to drain the water that has built up. there is a little hose with a plug in it located at the bottom rear under the exhaust hose. but be sure to drain it somewhere so that you don't ruin your floor. the water of course builds up from the ac's condensor. It doesn't take all that long to get full either.
Posted on Aug 04, 2008
FUEL GAUGE PROBLEM
Sending unit in fuel tank--possibly
Oct 01, 2014 | 1999 Buick LeSabre
Fuel gage goes from full to emty all the time. when it first stated it only did it with quater tank or less.
Sounds as if the SENDING UNIT in the tank is faulty. They work by RESISTANCE, so when the contacts on the fuel guage sending unit in the tank get worn, it will send incorrect data. Typically it will say full when the actually IS full, then, when the tank is 3/4 full, it will say EMPTY, and then, as you use more fuel from the tank, the guage will go from what is REALLY in the tank, to empty, at different times.
Only solution is to remove the fuel tank, and replace the sending unit guage assembly.
Jun 11, 2011 | Oldsmobile Aurora Cars & Trucks
Unit stops running after a few moments and says bucket is full, when it is empty.
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 14, 2011 | Kenmore Dehumidifiers
The gas gauge says full when you start the engine and the electric range says 446 miles to empty then it will all drop to empty and the gas light will come on, so i never know for sure how much gas I have.
Sending unit gas gauge in the gas tank has gone bad and will need to be replaced. The gas gauge wire is grounding out causing you to have full full indicated and when there is no ground you get empty signal.
This is caused by the gauge in the tank having a bad spot on the float, which is common from wear and tear. Also if your lucky, it may just be the wire harness from the gas tank to the frame might be the issue and will need to be replaced. It worst, it's going to be the sending unit it self.
Thank you for using fixya and good luck
Oct 11, 2010 | 1999 Oldsmobile Silhouette
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
Says gas is empty but when at the pump its stops filling.some gas exits back from the tank, I figure its my pin any way to find out if im full or not?
What Pin? Your sending unit is most likely worn out,on a 19 year old vehicle. Pull gas tank and replace complete assy,fuel pump and all,while your there.
Mar 27, 2010 | 1991 Ford F150
Isuzu rodeo 2001 6 cylinder check engine light always on
THE FUEL SENDING UNIT NEEDS TO BE REPLACED.. ITS IN THE TANK.. GOOD LUCK KEITH...
Mar 17, 2009 | 2001 Isuzu Rodeo
01 s10 gas gauge goes either full or empty
Sounds to be a faulty tank sender unit, these senders use a fine coiled wire on which a brush slides along to vary its resistance.
If the coiled wire breaks midway, the only readings will be full or empty.
I think sender unit is mounted to internal fuel pump on this model (top of fuel tank)
Hope this helps, regards
Aug 08, 2008 | 2001 Chevrolet S-10
Soleus KY-34 Portable Air Conditioner Logo
201 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
