Question about Hitachi 51UWX20B 51" Rear Projection Television
HDMI from laptop to DVI plug on Hitachi big screen TV
I have the cable connected securely but can NOT figure out how to get the Hitachi TV to recognize that connection.
  • William Hoffhines Jul 06, 2008
    I just bought this $50. HDMI to DVI cable - hooked it up = nothing. I go thru everything I can with the remote but it doesn't pick up on my cpomputer's output via the hdmi cord....
  • 6,487 Answers
To fix it, just turn the set off, let it discharge for a few hours. Reach in and remove the socket from the back of the tube and reinsert a few times to break through the corrosion.
This is a sign of weakness in the manufacturer of the guns and the connecting sockets. The metal used in the pin connections inside the socket are corroding and when you remove the socket and reinsert it cuts through the corrosion and makes good
contact again.
If still not working contact the support for your television..
Hope that helps......
Posted on Jul 06, 2008
  • 405 Answers
Have you cycled thru the inputs on the TV? Should display under the DVI input setting. Use input/source button on your remote to cycle thru inputs.
Hope this helps
  • Patrick McGee
    Patrick McGee Jul 06, 2008
    You may also have to go into your display properties in the control panel to turn on the output of the laptop.
  • Patrick McGee
    Please specify your version of windows and I can walk you thru the process of confirming that output is turned on.
    President:
  • 1,257 Answers
Can you please reply with some more details what you are trying to do.
HDTV Hitachi Ultrascan 50" resolution does not fit with my Toshiba Satellite laptop's HDMI
Look in your TV manual to see what resolutions your TV supports. Look at what resolutions your converter supports. Find the highest resolution that both the TV and converter match. Set your laptop to that resolution.
Mar 14, 2014 | Hitachi Televison & Video
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
Dec 31, 2008 | Hitachi 42HDS69 42 in. Plasma Television
DVI/HDMI Cable lost my pic and sound
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
Dec 09, 2008 | Hitachi 57F500 57" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 51UWX20B 51" Rear Projection Television Logo
1,118 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
