Question about Kenmore Elite 45986 Front Load Washer
Drain Overflow Recently replaced old washer w/ new washer. Now have water overflowing from standpipe everytime washer goes to spin cycle. Read suggestion in ref to others problem but our standpipe stands about 3 feet off the laundry room basement floor. Please help as this has been ongoing problem.
Always check the drain first for any stoppage. If drain over flow continues, and it is a newer washer or front load washer that uses less water. The problem is the size of your drain pipe. The newer washers have a much stronger pump that drains faster than the pipe can handle. 2 options: Either do some plumbing and change out to a larger drain pipe, or set up a laundry sink off to the side that the washer can drain into, and then can drain out at it's own speed.
Posted on Oct 25, 2012
Ur drain has a clog
Posted on Jul 08, 2008
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
The water drains too fast and overflows
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
May 14, 2010 | Kenmore 23822 Top Load Washer
My Inglis washer also gets stuck on rinse
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
All of the water filling my kenmore washer is flooding out bottom
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is filling up to wash but water goes out of tub before
Mar 16, 2009 | Washing Machines
Want to know how much water my model 44092 washer should use.
Mar 15, 2009 | Kenmore Energy Star 44092 Front Load...
Kenmore washer 23801-loses water during wash/rinse cycle before cycle completes
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Mar 12, 2009 | Kenmore Washing Machines
Thanks!! My estate washer sometimes will fill, most of the time not. I have found if I set it to rinse It starts the 1st cycle and fills the tank, but, after that I have to fill the tank with a garden hose...
Mar 09, 2009 | Washing Machines
Kenmore elite clothes washer model 22952
Feb 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
312 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
