Question about Philips Magnavox 20MT133S 20" TV
Smart lock got the tv from a friend and don't have the smart code. the tv blocks out any program w/ a pg-13 rating or higher. is there a master code?
  • Anonymous Dec 19, 2008
    I have the same problem, My mother forgot her code for the ratings.
  • Philips Master
  • 5,568 Answers
If that function was put in use by the previous owner, the fastest way to change the parental lock out would be to contact your friend and get the access code from them.
Since the set probably uses a bit of flash memory to store the access code and other settings, if an individual chip, that would have to be physically removed and replaced.
If you can locate service information on your set, it will likely contain a procedure to set the memory back to factory default.
Posted on Jul 08, 2008
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
I NEED A CODE TO WATCH CERTAIN PICTURE. CAN YOU HELP?
hi
do the following to exit the code option.
p { margin-bottom: 0.21cm; }
1.Press MENU to see the menu.
2.Press VOL+ or VOL- to highlight SET.
3.Press CH+ or CH- to select PARENTAL CONTROL.
4.Press VOL+ or VOL- to see the SECRET CODE screen.
5.Press the Number buttons to enter your four-digit secret code.
[The code will appear on the screen as you enter it. The code "0000" is the default of the
TV. If you have not set up a code previously, then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000").]
6.Press CH+ or CH- to select MASTER ENABLE, BLOCK UNRATED,or BLOCK NO RATING.
MASTER ENABLE: This is the "master switch" for Parental Control. When ON, all blocking/censoring is enabled.When OFF, all blocking/censoring is disabled.
BLOCK NO RATING: All programming with NO content advisory can be blocked if this feature is ON and MASTER ENABLE is ON.
BLOCK UNRATED: All unrated programs (based on Movie Ratings or TV Ratings) will be blocked if this feature is ON and MASTER ENABLE is ON.
7.Press VOL+ or VOL- to turn the blocking option ON or OFF.
8.Press TV/AV/EXIT to remove the menu from the screen.
ok
Jan 13, 2011 | Philips Magnavox 27MS343S 27" TV
Hi am looking an Instruction manual for a DSE LCD TV Model GE6400. This TV was brought at **** smith and it appears to be AWA product but there is no manual for it on there web site What the problem...
A friend of mine has also lost hi manual and can't turn off subtitles - did you have any joy locating a manual? Help would be appreciated.
Jan 04, 2011 | Televison & Video
How to disable TV-G
Press the Menu button on your remote.Scroll through the menu to the smart lock feature. The access code will be 0711 unless it has been changed. If this is not the correct code or you lost the code just unplug the unit for about 30 seconds. The 0711 code will then work. You can then chose to turn the Master Block off or change your blocked rating settings.
Aug 16, 2010 | Philips Magnavox 20MT133S 20" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Password reset
The Rating menu allows you to block playback
of DVDs based on their ratings.
Setting the Password & Rating Level
The DVD player allows you to block playback
of inappropriate content with a passwordprotected
Rating system (not all discs are rated).
A. From Stop mode, press SETUP.
B. Select Rating and press ENTER.
C. Select Rating and press ENTER repeatedly to set the rating from 1 (most restrictive)
to 8( least restrictive ).
If a password has already been set, the lock icon will be closed. You will not be
able to select Rating until you SELECT the correct password using the 0-9 keys.
D. Select Password.
E. Use the 0-9 keys to SELECT a 4-digit password and press ENTER. The lock icon will
close to indicate that the rating and password are set.
F. Press SETUP to save and exit.
Not all DVDs are rated.
DVDs that are rated higher than the level you select will not play without SELECTING
the correct password.
If you forget your Rating password, select 8888 to clear the memory. Keep this password
out of reach of children as if will always unlock the Parental Control setting.
If you need more help you can get the full manual from
http://www.retrevo.com
Thanks for using fixya
Aug 01, 2009 | Astar DVD-3800
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
32 inch sylvania tv
To fix the problem:
Nov 23, 2007 | Sylvania 6432TE 32" TV
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
Message protected program by tv-pg
Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
Apr 04, 2007 | Emerson EWV403 VHS VCR
Philips Magnavox 20MT133S 20" TV Logo
714 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
