Question about Samsung HP-R5072 50 in. Plasma HDTV
Freeze up my 50' plasma tv sometimes freezes up. It starts by showing a lot of pixels and then looses the signal. Other problem is that the blue light in the buttom never shut off.
2 thin vertical blue lines, near center and right side. Do i need to replace LRC buffer boards. Z50p3 50 in plasma.
By thin line I assume its one pixel in width. A single pixel wide line is an indicator of a defective panel.
Oct 30, 2013 | Zenith Z50P3 50 in. Plasma TV
Why is my Toshiba flat screen showing this red haze on screen?
Try adjusting the settings, You didn\'t supply the Model? Connected to Cable? Sat? Have you contacted your Provider? I can\'t tell much from the video ,Is it "pixels"? Sometimes my toshiba will freeze or become pixelated, it\'s the signal from Xfinity. Pull the plug on the TV cable/sat box wait 30 seconds ,plug in, saame with TV. A sort of reboot. Reset your setting to default. Satrt from the beginning of setup. Is it under warranty? Maybe you should be watching the Outback Bowl,
Jan 01, 2013 | Televison & Video
Thin blue line down middle of tv sometimes light blue sometimes navy blue Model PN50C430A1DXZA
Could be either a poor connection via a plug or ribbon cable or a defect on one of the boards.
Boards (if the trouble shows long enough) will have to be purchased and installed to see which if any is causing this.
Mar 14, 2012 | Samsung 50 in. Plasma TV
TV signal seems to "crack" with pixel distortion.
This is what digital signals do if there is not enough signal to paint the picture on your set. If you are using an antenna, then the signal coming from the station over the air is not strong enough or is being blocked by the trees and buildings. The TV needs a signal at least 60-70 % to get the data, and since the FCC mandated higher frequencies for over the air TV, the stations signal will not travel very far. You can try a better TV antenna, with a higher DB gain, but it seems to be a loosing battle for the present.
If you subscribe to cable TV and it is happening, then by all means complain to your Cable Provider as they should send yo a signal that will run your set.
Jan 17, 2011 | Sony KDL-46XBR4 46 in. LCD Television
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Red pixel snowflake effect
this is called cell mis-fire. sometimes this can be adjusted by a qualified service technician and repaired. however most times the " y- main " board will need to be replaced
Jan 16, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
50pc5d LG plasma TV Blue glow/red pixels
THIS PHENOMENON IS A CHARACTERISTIC OF PLASMA TV SETS...KNOWN AS DIFFUSION ERRORS OR COMMONLY..SPARKLING...ON LG SETS...THE PANEL VOLTAGES MUST BE CHECKED AND ADJUSTED IF NOT WITHIN .5 V...PLUS OR MINUS..Vs...and Va...THE OTHER ADJUSTMENTS ARE ON THE Y-SUS BOARD..Vset DOWN...Vset up...RAMP up...RAMP down...these should be adjusted by professional tv personnel with experence...JOE ACE
Mar 05, 2008 | LG 50PC5DC 50 in. Plasma HDTV
Pioneer Elite 1130HD
DAVE-UNFORTUNATELY ONE PIXEL IS STUCK ON AND TO FIX THAT PROBLEM WOULD MEAN REPLACING THE WHOLE PLASMA PANEL ITSELF.JOE TV
Nov 06, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Plasma TV
If you mean the picture froze or formed fuzzy pixelated picture and crackling, this will be due to a poor aerial signal to the tv, but if you mean the screen rolls with pink/white patchwork type squares and shows the picture in the background, all be it fuzzy, then that's the same fault as I am getting and have had to report the fault to LG as I am on my second TV. If it is the problem mentioned in the first sentence, it is happening to our friends in OS and they have been told by specialist aerial fitters, the signal is too weak for the tv.
Mar 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
