Input controls of GE TV Model 27GT613
I have a GE TV that has multiple inputs on the back of the TV I have a Coaxial cable coming from a VCR going to the Coaxial input and I would like to put a DVD player to the composit video jacks. I can not get the composit video to display
  • Anonymous Sep 10, 2008
    And I know the Solution, however it requires a Remote Control. for the DVD or Video game to work you must punch in channel 00 on the remote. If you attempt to scroll to the channel using the remote or the control on the TV it will not work.
SOURCE: Video Input
If your remote has a WHO*INPUT buton, that should allow you to select the front input.
Posted on Jan 29, 2007
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
  • 1694 Answers
SOURCE: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Posted on Nov 18, 2007
SOURCE: Using composite input.
there should be some type of input button on the remote to switch the tv from cable to composite or video 1 2 3 or 4. I'm not an expert or anything though
Posted on Jun 17, 2008
SOURCE: No remote for small Orion TV - Input mode?
If u cant get to the aux screen try holding down or pressing one of the channel buttons very quickly.
Good Luck!
Posted on Nov 30, 2008
OH. I have a DVD player/VCR Recorder. I have Cable TV. How do I connect DVD player/VCR recorder to Samsung Smart TV?
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Oct 06, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
How to connect old vcr-plus to emerson tv
If the TV has RCA jacks on the back, use the red, white and yellow ports on the VCR to connect to the same colors on the TV.
Dec 18, 2014 | Emerson Televison & Video
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
Trying to hook vcr up to an emerson telivision
Are you trying to connect with coaxial, or RCA jacks, If you have the Yellow, white, and red jacks on both you Emerson TV, and your whatever brand VCR, all you have to do is connect using the color to color ports. Sometimes the ports on tv or vcr are only mono, so instead of having 3 jacks there will only be 2. Yellow for video, and red and/or white for Audio. If you are using coaxial cables, which aren't hardly on the newer models. This also depends if you want to just playback or record as well. If you want to record with your vcr, you need to put the source coaxial,(From wall), and put that to the input of your VCR, it may be in the input of your tv, so you would take that out and put it in the vcr, and you will need a separate coaxial cable to put from your VCRs output jacks into the input of your tv. That would also put your input channel on 3 or 4. If you could tell me the way you wanted to connect, I could tell you better. Hope this helps.
Aug 02, 2009 | Emerson Televison & Video
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Taping
    If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
    Oct 12, 2008 | Televison & Video
    No coaxial connector on tv
    if it has an antana input the two screws on the back, you get an adapter from almost any department store for around 3 bucks.
    Aug 16, 2008 | GE 35GT740 35" TV
    Hd tv to vcr
    What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
     otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
    If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
    Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
    RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
    Yes, To change the input to video jacks, you must change the channel to 00.
    Jun 25, 2006 | RCA F27645 27" TV
    Televison & Video Logo
    412 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
