Question about Maytag Dishwashers
Dose not drain completely - Maytag Dishwashers
    Sergeant:
    Champion:
  • 330 Answers
Check the level of your drain hose underneath the sink between the dish washer cabinet and sink cabinet connect to the dispose position, sometimes if the middle part lower than the dispose will cause the back up problem, should be a little higher.
Posted on Jul 06, 2008
What is F78 fault?
It could simply be that the pipes under the sink where the dishwasher drain pipe fits are blocked with muck. This can prevent the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle. Solution is to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner.
Here is a link to a full repair manual: http://www.cagrimmett.com/justanswer/W1113tech.pdf
good luck!
Dec 01, 2010 | Miele Dishwashers
Miele dishwasher doesn't work.error F70
When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
Mar 29, 2010 | Dishwashers
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
My iphone dose not open when i plug it in to my computer whats wrong
Press and hold the sleep button (on top) and the home button, for about 10 seconds. The Apple logo should appear and your iphone rebooting.
You may need to connect to computer to recover using iTunes if the battery is completely drained.
Feb 22, 2010 | Apple iPhone Smartphone
I have a Kenmore 80 series and it will not drain but it dose go to the next cyclr and it dose spin can you tell me what the problem is Thank You Ray
IT SOUNDS LIKE A DRAIN PUMP. THE PUMP PROBABLY HAS AN OBSTRUCTION (KIDS SMALL SOCK). PULL THE PUMP AND LOOK INSIDE IT
Oct 28, 2009 | Kenmore 24902 Top Load Washer
The water dose not stop running washer dose not drain. dose not aggitate
You could have an issue with your pressure switch. If it does not see a high level of water, it wont switch off the supply. Suggest you inspect the pressure switch plastic tube for holes or a leak.
Oct 23, 2009 | Kenmore Washing Machines
MACHINE WILL NOT DRAIN COMPLETELY THEREFORE IT SMELLS
No washing machine drains completely , there is always residual water in the hoses and heater sump
If the machine smells do a couple of hot washes with no clothes in but add a good dose of soda crystals dissolved in hot water.
Pour this mix into the drum before you start the wash
Try going back to old fashioned soap powders for a few washes , these contain some bleach and soda which kill of the fats left inside your machine by the normal 40 & 60 degree washes
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
