Question about Hotpoint Refrigerators
Refriderator stuck on defrost - Hotpoint Refrigerators
  • 481 Answers
The defrost timer is bad, it is usually located inside the refrigerator with the control knobs.
Posted on Jul 06, 2008
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
May 05, 2014 | GE GSS22SGM Side by Side Refrigerator
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
I had purchase refriderator 5 yrs ago nw it is not defrosting properly I have to repair the same
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 30, 2010 | Samsung Refrigerators
Refriderator not staying cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 18, 2010 | Kenmore Refrigerators
The freezer has frost inside and everything is thawing out, the refridgerator is cool. I have tried to turn both sides up, but nothing.. Is it the compressor?
The pproblem is in your defrost system You have to check the defrost timer, Heating elements, and defrost thermostat. The coils have to be clean to have air flow to the refriderator side.
Apr 27, 2010 | GE GSH25JFR Side by Side Refrigerator
I have a 363.58275890 side by side refridgerator, the coil defroster wasreplace but the refriderator still isn't getting cold. does it have any other thremostats?
Your problem could be one of the following:
* compressor
* refrigerant-related issue (e.g.: a restriction or insufficient refrigerant)
* attachments to compressor (e.g.: relay, capacitor (if applicable), thermal overload)
*defrost timer
* defrost thermostat
Contact an appliance service company.
Feb 26, 2010 | Kenmore 53612 / 53614 Side by Side...
FREEZER WILL FREEZE BUT REFRIDERATOR NOT GETTING AS COLD AS IT SH
Sounds like you have a bad deforst heater or defrost limit. If you have to turn it off and let it defrost and it freezes up within 24-48 hours later, that's what you should look for.
Mar 30, 2009 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad. unthawing in freezer...
you have a defrost problem either a bimetal thermostat, defrost timer or a heater. open doors and unplug unit for 2 days to let defrost it will work great for a week or so. not to costly to fix either way
Feb 23, 2009 | Frigidaire FRS26R4A Side by Side...
Auto defrost failure fo Majic Chef refriderator model MCBR 1000W
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Refrigerators
HELP!
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 13, 2007 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
59 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
