Question about Kenmore 44832 Front Load Washer
Kenmore Door Jam
I just recently bought a Kenmore HE 2t front loading Washer, and i went to use it for the first time and the door wont open. The manual said to set it to arinse cycles and when I held start it said error F22. it sounds like the machine is trying to open the door but wont. Can this be fixed?
  • n_bluestein Jul 06, 2008
    I did not understand the last instructions. i need more detail for I know very little about washer mechanics
    I was trying to avoid this solution, but i will do
    Master:
  • 497 Answers
This is a common problem, please contact your service centre within the 90 days period, or guarantee period
All the best
Thanks for using Fixya
Posted on Jul 06, 2008
  • 6,487 Answers
Unfortunately, any electronically controlled digital appliance can have issues that regular mechanical washers won't. I always advice my customers to get the extended warranty on these electronically controlled digital appliances, as they have more that can go wrong with them. Because this problem is not easy to fix and usually result to having it replace..
You can try calling the support for this machine to check it for you but I think it will just result being replace with this error.
Hope that helps....
    Sergeant:
  • 275 Answers
Repair it to the nearest shop available. if it is under warranty period then it will be repair free of cost.
link for kenmore customer care is below
http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AH
  • 796 Answers
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
I have an front loading he 2t washing machine and I am getting the f21 error code. Also, the door is locked, The add garment, wash, and spin lights are on as well.
Hi, you have to unplug the washer from power source. Then remove front lower panel (3 sheet metal screw with 1/4" drive head located on the lower lop of the panel), open pump strainer (looks like a large stove knob, Turn it counter clockwise, lookout because lots of water will gush out. Back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump), re-assemble, plug to power, and turn-on. In my case, there was a piece of a metal lodge in the pump impeller.
Jul 13, 2011 | Kenmore HE2 Plus Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Washer is stuck on spin and the door wont open. It is locked.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.5 HE front load washer went haywire, doesn't work now..
Yes - the ECU is to blame, and is a common failure with this unit.
Jan 14, 2009 | Kenmore 43042 Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Weird smell
Probably mildew. They often suggest running a bleach only (no clothes) cycle every month or so with front-loading washers.
Oct 09, 2006 | Kenmore 44102 Front Load Washer
Kenmore 44832 Front Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
