Question about Toshiba 55H70 55" Rear Projection Television
Magnavox rear projection
Model #51mp392h\17
serial # ya1a0509043493
magnavox hdtv rear projection.
we get power and all the lights work but the red converge will not converge no matter what you do. the red converge won't even move left. it will not line up where it needs to. can someone help with this?
  • 8,596 Answers
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Posted on Jul 06, 2008
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
you will need to replace both convergence ics they are both STK392-120 and you will also need four 6.8 ohm 1 watt convergence resistors. You can get replacement ICs and the resistors at the following link and they provide free instaltion instructions with pictures so you can do the repair yourself.Here is the link.
http://servicemanuals.vstore.ca/
Jul 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
51mp392h/17 model number magnavox
try resoldering the vertical output IC. That may be the problem bad solder has been known to cause that symptom in the chassis
Mar 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 42in HDTV rear projection won't power on.
There is a reason why people give these away. Very expensive to repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
148 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
