Question about Samsung Cameras
When take photo it come up with message file error
  • 796 Answers
Try formatting your memory card once..
it must be having some corrupted files in it
Posted on Jul 06, 2008
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
File error blue screen
Photos cannot be loaded onto a card and then played back on the camera....it only works from camera to computer.
Mar 22, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Problem with yahoo mess 10..pls help
1. Before you attempt to transfer any files or photos, be sure that they are saved to your computer and that none are open, to avoid getting an error message
2. You may want to consider doing several smaller file transfers rather than a single large file transfer.
3. If you or your friend is behind a firewall and you're having difficulty transferring files or photos, try temporarily turning off the firewall to see if you're able to send them.
Feb 24, 2010 | Yahoo Messenger
Photos appear BLACK and/or "File error' at download
it may be because of your mode setting, go to menu den mode and set it to normal and maybe you wong get it in black
Jan 09, 2010 | Samsung S760 Digital Camera
Displays file error message when trying to playback still images and video footage
Did you take the card and insert into computer/device to view photos?
Viewing photos can alter the format of the photos thereby preventing your camera from reading them.
I viewed some photos and rotated a few photos and my camera no longer recognizes the format.
good luck
May 20, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
File Error now shows in camera for rotated photos from PC.
The camera will not display photos that have been edited by something else. Rotating counts as editing. Just opening a photo and then saving it without doing anything else counts as editing.
Apr 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
File errors, distorted photos.. I hate the Samsung L100!!
regarding the use, you have to check if you are using the right memory card for your camera.
you can only use 2GB sd card or 4gb sdhc card.
try this and if you still have an error message. you better send the camera for service.
Jan 19, 2009 | Samsung L100 Digital Camera
Disk error
Remove the files from your media player and then format the player. If you still receive this message, you will need to upgrade the firmware of this product.
Apr 23, 2008 | Delstar DS 917 Digital Media Player
Error message
Hi-
Its the operating system on the computer since it won't accept this types of images in your computer. Try saving the scanned document on a different folder/ or in your desktop. If everything fails, reformat your computer.
Hope this helps
Mar 16, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Help with nero photo viewer
How are you trying to open it? Are you trying to open it from within the application itself or by 2x-clicking on the .jpg?
Mar 03, 2008 | Ahead Software Nero 5.5 (NERO5.5) for PC
Cameras Logo
100 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
