Question about Olympus Stylus 770 SW Digital Camera
Blank Monitor Camera turns on (shutter opens) but the monitor is blank.
  • hhuffman1625 Jul 21, 2008
    I press the power button and the screen begins to light up but I am unable to take a photo. I can go and look at all the other pictures that I have taken but not able to take a new one. The shutter stays open and I did not drop my camera... please help.!!
  • peterw770sw Nov 30, 2008
    I have the same problem. The lens cover slides open and the displaty screen seems to start to activate but then it stays off. I can access the setup menu and have formatted the internal memory but still no luck. I have tried 2 different fully charged batteries but nothing seems to work. thsi camera was working 2 weeks ago, has not been in water since and has not been dropped. Any suggestions?
  • 796 Answers
There must be some improper connection with the main board and the display ....you should be taking it to the service tech...
this cannot be done at home..you may end up damaging the sensitive controls inside
Posted on Jul 06, 2008
Can my Nikon D50 be fixed or do I need to send it for repair?
This happens during malfunction of mirror and shutter.that is when cliked shutter opens but mirror did not go up so blank monitor screen hence no image in card. Take to skilled technician to replace shutter loader mechanism.
Apr 25, 2016 | Nikon D50 Digital Camera
I have the Canon Rebel T3i and having troubles with the LCD monitor. When I turn the DSLR camera on, the camera works perfectly fine. I can take pictures and the camera itself works perfectly. The...
Possible dead LCD? try these
1.press the play button to see if you can view photos
2. press the "disp." button near the shutter
if these fail. send it back for warranty
Jul 04, 2011 | Canon EOS 600D Rebel T3i Digital Camera
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
LCD screen is blank and pictures are also blank
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Jun 21, 2008 | Nikon Coolpix S4 Digital Camera
Monitor is blank, troubleshooting in manual does not solve problem
Um sorry but i'll i can say is bring it back to the retailer.
Dec 12, 2007 | Nikon COOLPIX L10 Digital Camera
Monitor is black w/ no image
This qualifies for the service advisory @ http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html. I had the same problem and they repaired it free of cost. Send it to them today.. Good Luck...
Apr 04, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 - Blank Viewfinder/Monitor
This is a known problem with the CCD - Nikon will replace at no charge. Go here: http://www.imaging-resource.com/badccds.html
Nov 21, 2006 | Nikon Coolpix 5700 Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
78 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
