Question about Compaq Presario Notebook
Wont boot up
When I turn on my presario X100 it shows Compaq logo and wont go any further. If I press F10 is says "entering setup" and never does.
  • Anonymous Feb 26, 2009
    compaq comp wnot boot up, i checked the hard driveand its fine when i put it in a differt laptop
  • 71 Answers
Hiya do you know if you have a recovery partition? if so pressing f12 on startup enters the recovery partition, the down side is if this does work you will lose everything as it will be back to factory settings
hope this helps
Posted on Jul 06, 2008
  • tony poole
    tony poole Jul 20, 2008
    you have rated as Inappropriate, did you look to see if you have a recovery partition?? if it hasnt and you got back to me i could have given you further instructions to rectify your problem
How do I change the boot order ? It some how changed after I formatted the hard drive it turns on but it wont read install cd or flash drive so can any one help me ?
Enter BOS setup
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
Boot menu Below is a summary of what is contained on the Boot tab of the BIOS Setup:
  • The order for the bottom process; for example: Removable devices, CD ROM, and hard drive.
  • Boot-time Diagnostic screen
strongly urge to update bios too when possible.
Apr 01, 2016 | HP Compaq Cq60-211dx Intel Celeron...
Presario v2000 wont boot it powers on then screen says press F1 or F10 but can go no farhter
Sounds like it is not seeing a bootable device, maybe bad hard drive, could be a bad setting in bios. Click here for tech support
Mar 26, 2013 | HP Compaq Presario V2000 Notebook
Compressed boot in win 7
boot the CD-Drive first. For more information please visit HERE.
Steps:
1.Insert the Windows 7 OS disc into your CD-drive and restart the computer.
2.Wait for the setup window to appear
3.Press Shift+F10 simultaneously to bring up Command Prompt
4.Type in Code: bootrec/fixboot then press enter
5.Last but not least type in Code: bootrec/fixmbr then press enter
Nov 19, 2011 | Compaq Presario 700 470024-192 Notebook
I have a compaq presario desktop S217ONX with two I-Inc monitors. I recently had to reinstall Windows Basic and only one works. I have read enough to be dangerous! Information is to go into BIOS adnd make...
Presarios normally let you access BIOS setup by pressing F10 as soon as the Compaq logo pops up on the screen when starting it. I've read that F1 is the key on some pre-2006 Presarios. Pressing the F10 key multiple times immediately after starting can be helpful.
Aug 21, 2011 | Compaq Presario SR1050NX (DW257A) PC...
Laptop compaq presario 2100. i want to reformat, installing new windows, but it will stuck to ENTERING SETUP, from the beginning
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
Dec 05, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
Hello i have a compaq presario 5000 when i turn
This is a compicated problem. First when it boots enter setup by pressing the F10. Once you are in set up reset all settings to default. Save changes and exit CMOS. If that does not help the situation have someone make you a boot disk, reenter setup and put the floppy as the first boot drive and then CDrom. Insert the boot disk, follow the instructions to boot. Once you are up and running try to roll back the computer to the last recovery point that worked. If that does not work you may need to see a local repair tech.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
My compaq laptop will not boot up
When you boot again, press whatever button it is to get into the bios, Delete, F10, whatever. Look for Boot Options. Make sure HDD is BEFORE Lan adapter/network.
Jan 13, 2009 | Compaq Presario Notebook
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
Non System Disk or Disk error Replace and strike any key when ready
while switching on your system press F10 and the go to the Advanced setup. There you select and press Enter key on change boot order and then change the order by using Page up or page down key. Alternatively you may use Esc key while showing the compaq logo on boot, you will be able to change the Boot Order.
Feb 08, 2008 | Compaq Armada 7770DMT Notebook
Compaq Presario Notebook Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
