Fender Passport 250 plus
The red "protect" light is on and now I have no sound for CD or microphone
  • ckcms5 Jul 07, 2008
    Thank you so much robotek!
    I took your advice and unfortunately the red light is still on when all speaker and microphone wires are removed so it must be the tower itself. :( I am calling several companies this morning to get it serviced. Your advice was very helpful and I really appreciate you taking the time to help me. :)
  • 1,512 Answers
Hi ckcms5
All I can give you is a confirmation on the fact that something has gone wrong with the head.
  1. First thing to do is check you speakers, and leads for short circuits. Best way to do this is plug them in normally, and check at the Head end from tip to sleeve of the Jack connector. If you measure anything lower than 4 ohms, or any dramatic differences between the speakers, then you have a problem with either a lead, or the speaker that shows low ohms.
  2. If the protection light is still on with the speakers disconnected from the head, then the head is faulty and will require a tech to check it out for you.
Be sure to do both tests. Sometimes it can be a short in the speaker side of things that blew the head up in the first place. Checking they are OK before plugging in your newly repaired head saves you from doing the whole exercise over again.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 07, 2008
I have the passport 250 on mic 1or 2 when pluged in microphone goes in and out 3-4 no problems
Read the section of the manual dealing with the voice over function for paging. Available here:http://support.fender.com/manuals/manuals_elec/fenderaudio//PassportP250.pdf Note pages 7, 8 and 9 especially 9 under VIP subject.
Jun 09, 2010 | Fender Passport Deluxe 500watt Sound...
We have blown a fuse in our Fender passport 250 ... where do we go to get a new one?
I dont know that amp but try taking the fuse to Maplins{UK} or RS electronic store for a replacement..
Mar 17, 2010 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
I would like to hook up my boss br 900 cd and a digitech vocalist 2 to my fender passport 250 could you please help me. Emery
1st connect the digitech vogalist
(Line Out L/R)
output to one (line input) from boss br 900 and the boss (line output) to the passport (stereo input) use a high quality cables, to supress noise efect, on output.
Jan 08, 2010 | Fender Passport P-10 Professional...
When the the Fender Passport 250 is plugged into the computer through the stereo out, there is feedback/buzz in addition to the sounds the microphones pick up, even when the mikes are off.
If there is a 120hz buzz then there is a ground loop between the computer and the passport. You need to get a ground isolator to go between the two. If the buzz is deeper the may be a audio ground off or the hum is comming from the power supply
Dec 27, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Fender Passport 250:
The manual is here if you don't have one:http://www.fender.com/support/manuals/pdfs/manuals_elec/fenderaudio/PassportP250.pdf Have a look at page 9 and read the VIP Channel 1 only section. It will explain the solution to your problem and the settings to overcome it. Please let me know if this helps.
Nov 29, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Passport shuts down
me too! i have the same problem did you ever find the answer??
Aug 28, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Fender Passport makes loud chirpping knocking sound after on for only 5 10 minutes
I have one that is doing the exact same thing. It's at a Fender
Authorized Service Center now. Hopefully dude can find the
problem. Fender says there is a 5 year warranty on it, so I
expect them to make good on their promise. Did you get
yours fixed?
Mar 11, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Fender Passport P-250
If you're still in need of a manual for your Fender Passport P-250 it can be found at:
Sep 27, 2008 | Fender Passport P-51 Consumer Microphone
Sorry about the delayed response, I just noticed this posting.
The protect indicates a problem with the output section of the amplifier. Effectively the amp has been shutdown to prevent further damage. Although the unit should not have been working (at least not well) at 30V, unless they htried to run it at full volume, there should not have been damage. The outputs are blown and this unit requires repair. If I remember these units correctly, there are 8 output transistors, most of which may require changing. WIthout seeing the unit and taking some measurements, I can not say for sure, but expect $40-$70 in parts.
Dan
Sep 03, 2008 | Fender Passport P-51 Consumer Microphone
174 people viewed this question
 Grubhead
Grubhead
