Question about Acer Aspire 5500 5570-2609 Laptop
Typing problem mis (see!) second of double strikes on keyboard. went into control panel/keyboard and put setings (again) as fast as possible-no help. is this just crappy product?
    Champion:
  • 258 Answers
Could be
Posted on Jul 29, 2008
On a hp pavilion a 1 1 10n I did somehing to cause
computer keyboards can have faults in several ways, but the most likely is liquids being spilt on them, causing them to do odd things or to just stop working completely.
There's loads of people having problems with this series of keyboards. With some keyboards the speed is wrong for them being checked (USB versions) and you can easily type faster than the keyboard controller can respond so it just goes nuts :-(
Notably, lots of laptops have a problem handling fast typing and tend to throw the cursor around or mis and add random letters.
Try a different keyboard just in case. Check its wire and connections for breaks/damage. Plug it into another USB port if possible some towers give lower power/resources to some USB ports - especially ones on the front of tower cases.
Also, some odd BIOS's allow you change the typing rate/speed (usually quite old ones though). If that value doesn't match your keyboard enough you can have problems.
Aug 06, 2013 | HP D8597A Keyboard
I have a manhattan wireless mouse, model number 176811. the pointer works fine but when i double left click to open anything nothing happens, i have to hit the button 3 or sometimes 4 times to open file??
You may not be double clicking fast enough. In the Windows System Control Panel, there is a Mouse Settings control panel. You can adjust the double click rate in the Mouse Settings control panel.
Aug 12, 2011 | Manhattan Mouse
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
  1. Click Start
  2. Click Control Panel
  3. Click the Ease of Access heading.
  4. Click Change how your keyboard works.
  5. Remove all the check mark in the box next to "Turn on Filter Keys".
Enjoy :)
~ Vikrant (India)
Dec 09, 2010 | HP Computers & Internet
All letters get typed twice ! aassddffgghhjjkkl
I've never experienced that. Suggestion take it into your provider repair shop and see if they can duplicate it. It might be a hardware problem or it might be you just aren't realizing you are hitting the key twice.
It’s help u.
And Thanks.
Mar 04, 2010 | Logitech Wireless Access Duo Optical...
Can't type double letters can't backspace more
Push the shift key down until it beeps and it should unlock the keyboard and allow you to type normally.
Feb 08, 2010 | Dell 0Y3740 Keyboard
Keyboard did not working......plz help me
either u r keyboard is having any dust or go to controll panel and set the keyboard properties or re arrange ur keyboard;
Jun 10, 2009 | Microsoft Windows XP Professional
My inspiron 1525 has a keyboard problem everytime i am typing it jumps back do you have any idea what's going on?
I've been struggling with this issue as well. I type really fast so I thought i was inadvertantly hitting the touchpad and moving the cursor. Maybe, maybe not. But today I discovered that changing one of the dafault settings for the touchpad has eliminating the jumping cursor trouble and I can type fast again without constantly checking my screen to see which line I'm actually typing in.
Here's what I did: Go to the control panel and the mouse and click on the icon for the touchpad and uncheck the touchpad setting "tap to click"
I also put my speed and sensitivity about in the mid-range. (Another suggestion that didn't work was to make my touchpad less sensitive).
Happy typing!
Feb 23, 2009 | Dell F3534 Touchpad
Logitech Cordless Mouse clicks too fast!
Try going into control panel, mouse, and set a longer delay for the double click.
Thanks and please take a moment to rate as FixYa. Thank you.
Jul 23, 2008 | Logitech Cordless Mouse
Logetech ubs Acess keyboard600
You have to clean matrix of keyboard. If you have machical keyboard then clean keys inside keyboard.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 01, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
