Question about M-Audio Delta 1010LT Sound Sound Card
Not all Inputs and Outputs are working
After setting up my studio, I found out that I was able to get outputs from only 1 and 2. The only inputs I have are 1,2 and 3. Can anyone tell me what to do get all inputs and outputs working ?
To answer your question I would go to the M-audio desktop icon and double click on it to open it up. Go to monitor and make shure that you bring the levels of each one of the tracks up to 2/3 rd up. Pan each one hard left and hard right and make shure mute is off. Click the top boxes at the bottom of the vu slot and see if that helps. Also you must save it or it will return to the previous settings.
Posted on Aug 15, 2008
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    Connect a CD player to LF320EM4A
    Hi, plug red and white rca connectors from cd player to audio in - rear of tv.
    Feb 02, 2015 | Emerson Televison & Video
    My cable box is hooked up but no signal can u tell me whats wrong
    If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
    How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
    Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
    You have to "tell" the TV which of the inputs:
    * coaxial (with TV set to Channel 3 or 4)
    * component
    * HDMI
    to "listen" to.
    Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
    Cubase studio 5 has deactivated the VST system links due to too many internal errors
    In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
    You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
    You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
    Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
    Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
    Vst system link errors
    May 23, 2012 | Lexicon Omega Desktop Computer Recording...
    How to connect mixer to a crown power base 2 amp and speakers
    just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
    Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
    Connecting an onkyo m282 to a vintage (1994)onkyo tx905 receiver
    I have found the solution.
    Using an Audioplex SPKCNV Speaker Level To Line Level Converter should resolve the connection issue.
    Jun 19, 2009 | Onkyo M-282 2-Channel Amplifier
    I wish to know the correct way to connect a Schneider 800w amp Model:spa-9705. What I have is a lead from my deck(marked sub woofer - 1 x red & 1 x black) but at the back of the amp in question it has 4 x...
    Hello i_starlin606,
    The Schneider SPA-9705 is a 4-channel bridgeable amp. How you intend to use it and what speaker(s) or subwoofer(s) you are connecting to it will determine the appropriate hookup.
    If used to drive 4 sets of normal speakers, you would connect your front channels to one set of inputs (usually 1 and 2) and the rear channels to the other set. You would not use the subwoofer outputs coming from the deck.
    If used to drive subwoofer(s), you would need two "Y" adapters with a female input side and 2 male outputs. The cables marked "subwoofer" would be plugged into the female "Y" and the male ends would be plugged into the 4 channel inputs on the amp (paired as 1-2 and 3-4). The front and rear preamp outputs on the deck would not be used.
    Speaker/subwoofer connections will depend of the number of individual speakers or subs, whether they have single or dual voice coils, and the impedances of the voice coils.
    Hope this helps.
    May 06, 2009 | Car Audio & Video
    How do I know which converter box to buy?
    here are the specs for the Magnavox TB100MW9
    Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
    Jan 04, 2009 | Televison & Video
    DELTA 10/10/LT INPUT/OUTPUT PROBLRM
    Well I guess my problem is a little less important. I have 1-2 3-4 5-? 7-8. I dont know where 6 went. I even checked to see if I could plug a wire into the input and toutch it with my finger to see if I got a vu response, Nothing.
    Jul 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
    M-Audio Delta 1010LT Sound Sound Card Logo
    224 people viewed this question
    Top M-Audio Computers & Internet Experts
    Gareth Cockram
    Gareth Cockram
    mukhtar21 shaikh
    mukhtar21 shaikh
    John Bolton
    Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
