Question about Simrad GPS
Only turns starboard, simrad wp32
I have a simrad wp32 auto pilot that is only turning to starboard and won't shut off, continues to run even after hitting the stand-by button. Can you help me with a possable fix?
Cheers, Doug Alexander
pls. email to: ejgregory2002@yahoo.com
SOURCE: RCA 32V432T television ,Turns on and off on its own and runs through channels continuously
The problem is most DEFFINATELY the control board behind the user buttons.
You have 3 options to fix this...
1. Replace the new board completely (no garuntee your getting a "new" part).
2. Replace the tack switches (requires soldering and patients [alot of them]).
3. Remove the board and snip the one wire marked "Key". I didn't snip it so much as correctly pulled the wire out of the plug itself. By removing that one wire from the board you disable just the buttons. You still have complete use of the remote. Who the heck walks over to the TV these days anyway!?!?
Posted on Oct 23, 2008
  • 31 Answers
SOURCE: my streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
SOURCE: i cannot turn on my wireless capability
To the satellite E105 S1402 with WiFi problems. The solution is:
1. Make sure that your router is operational.
2. Make sure that the WiFi switch is on.
3. If your Wifi used to work out of the box, then you need to buy a Flash Drive (if you don't already own one), then you need to do a Backup of all your users documents on the Laptop.
4. Use the CD's that came in the box to re-install Vista 64.
Don't waste time with Toshiba support, you will end up in Phillipines and quite honestly, I am shocked that Toshiba does not have a better support process.
I had the same problem and I had to re-install the OS. It is not that painfull to do and should take about 1/2 hour.
Cons: You have to re-install additional software that you installed after purchasing your laptop.
Posted on Jul 24, 2009
ajuhere81
  • 256 Answers
SOURCE: Help me pls. i need motherboard driver installer
you can download the drivers from the follwoing link pls.
http://www.matsonic.com/drivers/view.php?modelID=MS9147C
Posted on Sep 04, 2009
  • 38 Answers
SOURCE: autopilot can not sense rudder movment
Check rudder reference unit wiring
Posted on Jun 24, 2010
If I shut off the blower on my gas furnace do I have to shut down the whole furnace
Turn of the system at the thermostat. If you turn off the blower, assuming you mean at the tstat, there's no need to turn off the pilot. If blower is running and won't stop, even if turned off at tstat, turn off power by any means necessary, and pilot does not need to be turned off. A "standing pilot" is made to stay lit at all times, running or not.
Mar 07, 2017 | Heating & Cooling
Turns hard to starboard when in auto
Verify that it is configured for your installation. Some units can be installed either on the port or starboard side, and they have to be programmed accordingly. Verify this in the user's manual.
Jul 04, 2013 | Raymarine St8002 Smartpilot Autopilot...
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
Heater does not turn on
If you have a gas hot water heater that won't stay on, check to see if pilot light is out and relight it if it is. If you have an electric hot water heater that won't stay on, then you should have an electrician check the wiring.
if you need an auto tool you can click here: chinasinoy.com
Nov 05, 2012 | 1990 Toyota Corolla
My Simrad GPS/sounder won't turn on.
assuming you have checked fuses etc you may have to use it as a lunch hook for your dingy...seriuosly..don't know ow old t is but a replacement is order methinks ...just like laptops they have improved greatly now and features abound screens are bigger and better...price has also dropped?
May 27, 2012 | Simrad GPS
MY SIMRAD AUTO pilot is telling me rudder error what is the problem is it the linear feed back cylinder
Has it ever worked?
What has changed?
Is it the a "pole/linear" or a "rotary" FB unit?
Out of the 5 basic parts of the AP system, the RFB is the most replaced due to the environment (Splash, heat, vibration, mech movemnet).
"Rudder feedback error"
does not see the RFB at all.
check the connections in the J-box first.
you should be able to manually turn your wheel and see the RFB indicator change on the control head.
"rudder responce error"
does not see the RFB move when the AP is given a command.
then check physical connections.
could be loose, could be backward?
Nov 28, 2010 | Simrad Lf3000 Linear Feedback 20188074...
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
GPS Logo
85 people viewed this question
Top Simrad GPS Experts
Will Halftowaite
Are you a Simrad GPS Expert? Answer questions, earn points and help others
