Question about Intel Motherboard
Laptop how i work motherboard dead
    Problem Solver:
  • 9 Answers
Pls if ur motherboard dead if it is in warrenty pls exchange it
Posted on Jul 31, 2008
Completely dead laptop
there must be the problem with laptops motherboard
most probably you should call customer care and said them to change the motherboard or if laptop is not under warrenty you can go to some local shop and show it to him (it will cost you less)
Jul 05, 2013 | Toshiba satellite c660
I have a Philips Freevents X57 Laptop which has a motherboard problem. When I switch the laptop "ON" these are the following symtoms: A) Power Charger in AC/DC Socket without battery: Power...
Possibilities:
* leaking/bad capacitors on the motherboard, not doing their job, i.e., causing voltage fluctuations that the motherboard cannot tolerate;
* dead disk-drive -- cannot boot Windows from a "dead" drive;
* dead CPU -- cannot do anything other than power on/off;
* failing power-supply -- not supplying correct voltages to the motherboard.
Take the laptop to a qualified computer technician, for professional trouble-shooting, and probably a replacement of the motherboard. But, it might be less expensive to "salvage" the disk-drive (and your files) from the laptop, and to buy a new laptop, than it would be to buy a replacement motherboard, and pay for installation.
May 20, 2011 | Philips (142440) Computer Speakers
LAPTOP does not turn on. only fan runs.
Things to check first.
1. Make sure you have a new BIOS battery installed. Some computers will not start if the battery for the BIOS is dead.
2. The CPU may have overheated and no longer works. I lost a CPU and everything was dead.
3. A dead motherboard can also act in like manner.
Sometimes something will come loose on the motherboard causing a direct short which of course fries the motherboard and probably the CPU. Dropping a laptop can shake things loose.
My Daughter had this happen with hers. It was a 800 dollar HP Compaq and I had a heatsink come loose on my HP Compaq which fried CPU AND Motherboard. Beware of HP since they bought Compaq.
Jan 25, 2011 | Intel Computers & Internet
I have laptop this is totly dead when i open this laptop how can posible
Dead AC adapter?
Dead battery?
Dead motherboard?
Dead CPU?
Take it to a qualified technician, for professional trouble-shooting.
May 14, 2010 | Dell XPS M1330 Laptop
Whilst in use went completly dead canot resart
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 02, 2009 | HP Pavilion dv6000z Notebook
I have power out of adapter but laptop is completely dead; no lights come on at all.
Oct 16, 2009 | Toshiba Satellite A45-S150 Notebook
My loptop is an Averatec 7100. How can I test the motherboard? I took it to a computer repair shop and they said is the motherboard, I want to know how can I test it on my own.
This is more of a system diagnosis that an actual motherboard testing procedure, but since all components attach to the motherboard in one way or another it could count as a prcess of elimination......
Oct 13, 2009 | Computers & Internet
Dell latitude d500 had a power socket problem, but now resolved pc will not boot-up, drive spins-up, then nothing, completely dead display i think most likely scenario is mobo is fried, but open to...
Oct 10, 2009 | Dell Latitude D500 Notebook
My inspiron 5160 doesnt power up.
It should power up with the external power supply if it is working properly; you can remove the batteries and it should still work with the external source. If not, then the power section on the laptop is dead and needs servicing.
Oct 03, 2009 | Dell (8N816) Motherboard
CF72
have had motherboards become static choked, and all you can do if this is the case is to leave it plugged in to power supply, but turned off, for a day or two. don't know if it works with laptops, but sure works great with "dead" motherboards.
Dec 10, 2007 | Panasonic Toughbook 72 Notebook
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
