Question about Honeywell Programmable Thermostat Heater
Heating and Cooling Thermostat - can't get the wires right
Hi All,
Hope you can help me on this one. I have a honeywell programmable thermostat. Coming from my wall I have: a red, white, black, green and orange wire. In the winter, I successfully made the heater work by hooking up the red to the Rh input, had a jumper connecting to the Rc input and hooked up the white wire to the W. The black wire did not connect anything. The green and orange wires were buried and not used in the prior connection (the prior thermostat was an old-school dial-type). I turned on the AC this summer and could not get it to work. I have made the AC unit and blower kick on by manually touching the black and white wires. I can't seem to make the thermostat kick on the AC, though, having tried quite a few combinations. I have done all of the normal troubleshooting stuff - have narrowed it down to my incorrect wiring. I have Rc, Rh, W, Y and G inputs into the thermostat.
Help me make the right connections! Thanks everyone!
    Problem Solver:
  • 12 Answers
You most likely do not have AC.
Red to R (24volts), White to W(heat).
Black(usually common), Orange(usually reversing valve for a heat pump, could be anything you want it to be as long as you wire it on both ends correctly), and Green (usually FAN) were buried, so they were never used.
Posted on Jul 23, 2009
  • 308 Answers
Depending on if you have gas or oil heat the connections would be slightly different, but if you were only using the red, white, and black before, this should work. Red to Rc with jumper to Rh (or vise versa..) White to white, and Black to your Y terminal. Your Rc and Rh terminals are your 24 v supply, Yellow is connected to your outdoor unit, and W is the common for the heat, and G is for you high speed fan. Hope this helps
Posted on Jul 09, 2009
I have 2 wires coming from the wall, 1 white and 1 blue and want to wire a new honeywell 5-1-1 day programmable thermostat.
likely one wire to TH, the other to W if the thermostat operates on batteries. If the thermostat requires a 24 volt power source it is not compatible with your system.
Oct 09, 2017 | Honeywell Heating & Cooling
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Im replacing my honeywell with a hunter 44110 the honeywell has 6 wires w1 to white, w2 to blk, G to green, RH to Red, Y2 to yellow and Y1 to orange, the hunter only has G RH RC Y W
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Hunter Fan Company 5/1/1 Programmable...
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
Trying to connect kenmore heat pump thermostat to honeywell therm
reversing valve orange wire goes to o or b terminal depending if energized in heating or cooling
May 11, 2009 | Honeywell Programmable Thermostat Heater
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
378 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
