Question about Sony Playstation 3 (PS3) Console
Turning on when i turn the pss3 on after about 3 seconds it will flash amber and then turn itself off, also it is saying there is no disk in there when there is, how can i fix this.
Your internal power unit has fused
Posted on Jul 06, 2008
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Dec 21, 2014 | Pride Health & Beauty
PANASONIC PT60LC14 SHUTS OFF AMBER POWER LIGHT BLINKS 1 TIME EVERY 5 SECONDS
According to service manual when the power button flashes amber once every 5
seconds there is a problem with one of the fans not turning or up to speed or related circuit on the projection assembly.
Nov 23, 2011 | Panasonic PT-43LC14 43" Rear Projection...
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Station turns on then beeps and goes briefly amber then turns off. wont accept controller turn on? any ideas?
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...
or click here to download repair guide
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
This is my second dockstar, and both have just gone to rapid blinking amber lites. seagate doesn't really tell you any thing.
moz-screenshot.pngmoz-screenshot-1.png1-If you never shut off the device try to turn off for 4 hours and try to use it again.
2-The bottom light must flash when is on,if not you have a power supply or net cable problem.
3-If the top light is amber is indicate you have a disk problem
4-Do a power cycle
5-if the problem continues run the disk diagnosis utility from the web interface
6-If fails the drive needs replacement, check for warranty
7-Try to do a system reset.Press and hold the switch( a small hole at the bottom of the Ethernet) until the top front light flash and allow the unit to restart.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 01, 2010 | Seagate FreeAgent DockStar Network Adapter...
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
PC will NOT turn on;flashing amber lights
The power LED Flashing AMBER indicates the power supply in the tower has failed and needs replacement.
You can get a replacement here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817165004
Dec 20, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
My camera keeps turning itself off and the amber light keeps flashing
Please check whether the battery is fully charged.
Please try using a different battery.
If the issue still persists after changing the battery try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Panny pt-50lc13 steady amber flashing light
Sounds like a defective lamp diever or ballast.Listen for a buzzing sound when you turn the set on. If you do not hear it then most likely you have a bad ballast or lamp driver. Worst case scenerio would be the engine itself.
Dec 28, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
