I am trying to set up a belkin wireless g router (802.11g) to my cable modem. i have followed the manual and the installation software. the router seems to connect and configure itself successfully but it can not locate a internet signal. please could you help?
    President:
  • 1,314 Answers
Most likely you need to change the IP address of the routher because your cable modem uses 192.168.1.1 which is the default for many routers. So either use the disk that came with your router or login to your router and change it to 192.168.2.1. That will solve the conflict and allow you to connect.
Thanks and please take a moment to rate as fixya.
Posted on Jul 06, 2008
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
How do i set up the internet security on my belkin wireless router
Place your wireless G router in a wide open and central location. Don't connectthe power plug into the router, yet. Make sure your computer is turned off. 2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernetcable from your PC and insert it into the wireless G router's WAN port. Youshould have an additional Ethernet cable that came with your router. Take thiscable and plug one end into one of the LAN ports on the router. Then connectthe other end to your PC's Ethernet port. 3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll takeapproximately 30 seconds for the modem to boot up. Connect the power plugadapter to the router and the other end into a power strip or outlet. Like themodem, it'll take about 30 seconds for the router to boot. Turn on your PC. 4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LANlight. If you don't see any of them lit, confirm these devices are turned on.Make sure the Ethernet cable connections are installed correctly. 5. Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router.Set up features, such as creating your password and setting up your time zone.Continue to follow the setup wizard so you can configure ?other settings.
Sep 20, 2010 | Belkin (F5D5231-4) Router
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I need to change the name of my Belkin Wireless (automatic) name and password. Can you walk me through this?
2. Step 2
3. Step 3
4. Step 4
5. Step 5
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 01, 2010 | Computers & Internet
I cant connect to the internet
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
INetwork Password
ask your internet service provider
May 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I need to enter my code
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 23, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Dec 09, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
