Question about Bosch Dishwashers
Hello, I have a Bosch SHU055A05UC dishwasher that does not drain. I've tried reseting the panel and clearing any clog that is close. Any thoughts?
    Sergeant:
    Champion:
  • 330 Answers
Maybe the drain motor has problem, check the wire first, unplug it and put it back again. see what's going on
Posted on Jul 06, 2008
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
My bosch dishwasher counts down to 1 minute on any cycle but will not drain except by manually hitting cancel. I've replaced a defective drain pump but it still does this- any ideas?
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 18, 2013 | Bosch Dishwashers
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
THE WATER WILL NOT DRAIN OUT
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The water is not draining from the bottom of the dishwasher
Kevin
Dec 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
Bosch dishwasher not draining-I have cleaned the filters, checked the hoses. No know plumbing problems what's next? Is there a reset button?
make sure there is not air in the line and that the cage where all the water drains down into in not blocked or clogged. so first take the drain line out and completely empty it out. next ck the inside where the water falls down into to drain and ck for stoppage.
Apr 28, 2009 | Bosch Evolution 500 SHE55M05UC Stainless...
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
