Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Annalog power safe mode
We have just moved and our monitor seems to be set up properly because we have power and we get a little window that pops up saying annalog power safe mode and then the screen goes black and we get nothing else. Help
  • 3,940 Answers
Could be a could a couple of things
#1 Ensure the video cable is connected to the correct jack on the tower (Some systems have both an integrated video card and an Expansion card. See if there are 2 blue 15 pin vga ports, if there are 2, connect to the other one.
#2 You may be using DVI (White connection) and have the imput select set to D-Sub (Analog) Use the input select button on the monitor to sleect DVI
Posted on Jul 06, 2008
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Out of range
When your wxternal monitor says "Out of Range" it may mean that your resolution settings on your computer are set too high.
One way to diagnose and solve this is to reboot your machine.
During bootup press the F8 button to enter Safe Mode.
When prompted, select Safe Mode.
Your machine will then boot up with the mnimum amount of drivers required to run the Windows operating system.
Once you have loggin into your computer, right-click on the Desktop and select Properties.
The Display Prpoerties window will pop up. Select the Settings tab.
Slide the idicator to 1024x768 and hit Apply, then Ok.
Restart your computer and your monitory should display your computer screen.
Please classify this with the appropriate computer brand and model.
May 14, 2010 | Computers & Internet
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor in safe mode
Try and do a repair install. - Pop in your operating system disc - Click Repair Install
If it doesn't work, do a fresh installation of your operating system. Good Luck.
Jan 13, 2010 | Dell E173FP 17" LCD Monitor
I need to reset the display settings but i cant see what they say
It's a simple fix. Reboot your computer and press the F8 key repeatedly until you come to a boot menu. Select Safe Mode. This will take you into Windows at a default of 640x480 resolution. Adjust the settings according to the monitor and lower them to what you had them before you did the changes.
Another method is when you are at the boot menu selection, you can select safe mode with command prompt.
Type c:\windows\system32\restore\rstrui.exe for windows xp to use the system restore and rollback windows to when it was working properly.
For windows vista type:
c:\windows\system32\rstrui.exe
Jul 27, 2009 | Acer Aspire™ T180 PC Desktop
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Will not restart, has been deadlocked in power safe. I pressed any key and moved the mouse. Nothing.
Sounds to me that Windows is setting your computers video controller to output a video signal whose timing is not compatible with your display. You may be able to boot Windows in safe mode and then be able to pick a compatible video timing ( refresh rate) in the display settings Windows control panel. Did your monitor come with any kind of setup disk?
If your monitor is a flat panel try the resolution refresh rate at 60MHz. Lower than a CRT.
Hope this does it for you, please leave rating...
May 15, 2009 | Dell Dimension 8300 PC Desktop
My moniter says out of range.
Video Card has a resolution setting higher than the monitor supports. The below works with XP, may work for Vista as well
Start the PC
Start hitting the F8 key repeatedly until you see a menu
Choose Safe Mode (make sure not to pick safe mode command prompt)
Once you see the desktop, right click on an empty area on the desktop, then choose properties
Find the resolution property in this program and bring it down. 1024 x 768 should be ok
Click on OK til the window disappears
Reboot
Mar 19, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
I was trying to adjust the monitor settings on my Westinghouse LCM 17x7 monitor. When I hit apply, the screen went black with an "Out of Range" error message. I can not get back to my desktop to try to...
Reboot and hit F8 continuously after the beep. Choose Safe Mode. Open the
configuration window again. Move the bar and then move it back to whatever
Safe Mode had it set at. Hit apply. Reboot.
Feb 02, 2009 | Computers & Internet
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
96 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
