When the phone is pluged in i can't use my broadband
  • 165 Answers
U need to installl dsl filters
Posted on Jul 07, 2008
Compacq Presario CQ60-419WM, can't connect to AOL.
Its true that you need broadband to use the router and then need the router for wireless networking.
Nov 03, 2009 | Computers & Internet
The magic jack is pluged into the phoneline directly
OK.. First of all, I am hoping you understand the basics of the MagicJack concept ?? Highspeed Internet connection on your PC, MagicJack plugged into your USB port, with a phone plugged into the other end of the MagicJack ? It requires High Speed, no dial up, and marginally works on my wireless Broadband due to atmospheric influences. It DOES work on my bluetooth wireless cell modem just based on the better speeds I get from the modem vs. my wireless Broadband.
1. If you have a Cable Modem or Wireless Broadband Dish for internet, follow the steps below.. IF you have DSL, skip to # 2.. if you have Dial-up skip to # 3,
I personally own wireless Broadband, so my ongoing experience is from here. I own a MagicJack for traveling and a Vonage line, for my house fax line service because the MagicJack is not strong enough, power wise, to push through my CAT/5 house, phone lines. Vonage does provide phone for the entire house, for the most part, cleanly, because Vonage uses a powered router to provide the final signal, which I then jumber over to a phone jack to connect into the house. It also requires that you disconnect your external phone lines, that would normally go back to the "Big Bad Phone Company". This can be done at the demarcation point, where your regular phone lines connect into a box, outside your house ? The internet I have, is in my shop, about 150' from the main house, Vonage's router power's the whole house, just fine.
2. With DSL, you will have good solid speeds, but you will still have the issue of, MagicJack, being too low in it's power source, because it comes from the USB port of your PC. You are basically going to be stuck with a single wireless or corded phone, for the MagicJack service. In this case, since the DSL is fed through the BBPC phone lines, you will not be able to 'pipe', even Vonage back through your house phone lines.
3. If you're on dialup, you're going to have poor service, out of the box.. you're just not going to be fast enough to be clean.
As an added note.. Your query for help is concerning.. again, high speed internet into your PC, MagicJack plugged into your PC's USB port, the phone plugs into the MagicJack's RJ-11 phone port.
Thank you for your time in these matters.
Respectfully,
Toby White-Beebe
P.O. Box 474
Penryn, CA. 95663
(916) 300-9410 Cell
(916) 473-7409 Home Fax
2008 VA Certified NACI Low Risk Security Clearance
2008 VA OCIS/ROB Affirmation of Compliance
2008 VA Certified OIT Contractor
2008 Dell Certified Lead Systems Expert - DCSE
1999 A+ Certified Service Technician
Aug 08, 2009 | Computers & Internet
I pluged in the power but it won't turn on
Mismatched power supply, bad AC outlet, and/or dead router.
If under warranty, get a return authorization.
Jul 09, 2009 | Dell TrueMobile 2300 Wireless Broadband...
I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
Hi Brenda,
Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
Dec 17, 2008 | Lexmark Computers & Internet
DCT 646
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Dec 16, 2008 | Uniden DCT646-2 Cordless Phone
NETWORK ADAPTER
Reinstall the network adapter from the dell driver cd and reboot the system with the nic pluged in.
Jul 21, 2008 | Dell Dimension 4600 PC Desktop
Will not conect, Error 678, tryed resetting modem it was resetting, now nothing I pluged a phone in with out a microfilter would this damage the modem ??
If this is a dial up to Broadband connection. Double check your username and password.You must use the microfilter as this differentiates the signal on your phoneline.If you are connecting through a Router.Go to Internet Options in internet Explorer to advanced and make sure all check marks are removed in Lan settings/.
Jul 12, 2008 | Computers & Internet
Loosing Signal
How many extensions do you have ? and do you have broadband (adsl) ? sometime's this could be just down to the phone line - if you have broadband (adsl) there has to be a filter pluged in on all other extensions, do know i'm guessing let me know this could be your problem as the filter is blocking the signal or interfering.
Aug 26, 2006 | British Telecom Synergy 2110 Cordless...
Computers & Internet Logo
David Payne
David Payne
