Question about Ruud Heating & Cooling
Rheem Central Air united stopped working, no hum but power is there
I have turned down thermostate and waited. Nothing. Turned off breaker that feed the outside breaker and made sure no power. I checked the old breaker , seems okay and using my electrical power indicator the unit is getting power.
Furnace blower is fine.
  • 254 Answers
It looks as if the 24 signal from the thermostat is not getting to the contactor. Or possibly the coil in the contactor itself is dead. Or a third option may be a bad control power board in the condensing unit itself. If you feel comfortable reading through these devices comment back. PLEASE REMEMBER THERE IS HIGH VOLTAGE INSIDE THE CONDENSER AND A CAPACITOR.
Posted on Jul 06, 2008
Humming noise after a/c broken
If you're scared something will happen, turn off its circuit breaker.
May 05, 2012 | Carrier Heating & Cooling
The fan on the Ruud furnice unit runs all the time but the Ruud ac unit is not kicking on . I know nothing about any of this but would like some Ideas what I might check. I went outside and could not find...
Some Ruuds have a red rubber cap reset button on the bottom of the unit or inside. Usually the fan quits and trips the switch. Or look at the metal run cap with 3 leads on it, if it looks bulged(concave on top) and not flat and sunk in, replace that and ur good to go. Let me know. Please pull the power disconnect if you attack the cap, and write down what leads come off which terminals.
Aug 14, 2010 | Ruud Central System Air Conditioner
Hi i have a rheem central air unit. The outside unit does not want to turn on. i just recharged it with freon about a month ago so it cant be that
Check the circuit breaker(s) for the outdoor unit. Then set the thermostat to make the unit come on and see if the contactor pulls in. If it doesn't turn the fan switch from auto to on and see if the indoor fan comes on. If not your transformer could be shot. If the contactor pulled in on the outside unit check the capacitor for the fan and compressor.
May 21, 2010 | Heating & Cooling
Breaker trips when unit is turmed on
this could be a bad capacitor,a shorted wire or bad run windings in the compressor.
Aug 16, 2009 | Heating & Cooling
Central air does not kick in.
It sounds like you have a bad capacitor to the compressor. The humming noise is the compressor not starting up but is trying. It is either the capacitor or the compressor form your description. If you had a lightning storm or power surge about the time this happened it is most likely a bad capacitor. You can have the capacitor tested to see. Disconnect power before working on unit!
Aug 05, 2009 | Honeywell ER150B Air Conditioner
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
My intertherm is not working at all
check the breakers at the bottom of the unit. the ones for the heat strips may be tripped.
Oct 28, 2008 | Heating & Cooling
Central air unit problem
Check inside that breaker box for fuses.
Sep 06, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
