Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer freezing up
I have to defrost my freezer every couple of days and the fridge isn't cooling either. What could be the problem.
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Freezer side seems to work but the refrigerator side isn't
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 11, 2011 | Maytag Refrigerators
GE Refrigerator isn't cooling properly freezer is freezing ice
You have a defrost problem !
The fridge isn`t defrosting automatically . Although it`s likely the defrost timer motor seized , it could also be the defrost termination switch , also known as the DTS switch , (or limiter switch) ..... or the defrost heater itself .
Any one of those three will give you the exact same symptoms .
You can diagnose this problem yourself simply by emptying the fridge , unplugging it with the doors slightly open , and letting it defrost for a good 24 to 48 hours .
Plug it back in , and let it run for about 12 to 18 hours . If the temperatures are OK after that , and remain OK for a few days , the problem is exactly as I described .
A defrost timer is worth about $30 to $40 .......... a DTS about $10 to $12 ............. and a heater anywhere between $25 to $75 , depending on the model .
Jul 03, 2011 | GE Refrigerators
Foods are freezing when in the crispers or towards the back
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
64 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
