Question about Gateway (SL1450-30151382) PC Notebook
Gateway Notebook PC 7330 GZ Power Problem
My Gateway notebook 7330GZ notebook has been working without incident.  Now it will not turn on.  The AC status light is lit and the battery charging light is lit.  Any solutions
  • Anonymous Jul 25, 2008
    was working good, but suddenly it do not charge and the light of the power is lit no power on, i change the power adapter and the problem is the same , the light is lit.
The most common problem is the plastic that covers the switch breaks. It's a poor design. Take out two screws along the top edge from the bottom near the middle and pry off the keyboard access cover. Then take off the circuit board and you should be able to turn it on and off.
Posted on Nov 17, 2008
Gateway 7330 gz shuts off or monitor flickers
This probably isn't a driver problem. Your backlight power cable is probably loose. You can tell by getting a flashlight and looking closely at your monitor while it's powered on. If you can see your desktop items then it's a backlight cable problem. I had the same problem with my Gateway. You can remove the front bezel from your display to get to the cable. I just pressed mine up into the display as much as possible and put a little hot glue on it to keep it from backing out. I never had the flickering problem again. Good luck.
Jan 28, 2013 | Gateway 7330GZ Notebook
Flickering power light on gateway 7330 laptop
Return the laptop to the place of purchase, this is a manufacture issue.
Jun 20, 2012 | Gateway 7330GZ Notebook
Laptop will not come on. Indicates that it is connected to power source although it is loose. What should I do? Is it the motherboard or the d/c adapter? I have a Gateway 7330 GZ.
Try another 19volts adapter. If problem still the same and the laptop not powering-on, there's something wrong with the motherboard circuit and not the DC JACK cause it indicates that you connect an adapter.
Apr 05, 2010 | Gateway 7330GZ Notebook
Clean install of Windows 7 on Gateway 7330. Cannot get sound or wireless working. Help?
go to the gateway 7330 page of the gateway official website. download the vista drivers for the system. when you want to install, right click and select "install with troubleshooting". then follow the instruction from there.
Jan 23, 2010 | Gateway 7330GZ Notebook
My gateway 7330 will not reboot.white letters and black screen er
format your system and re install Windows,
this is master boot problem.
Jun 30, 2009 | Gateway 7330GZ Notebook
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
7330GZ won't turn on
I had the same thing happen to my computer 7330 gz and all the trouble was caused by a faulty ac adaptor. Battery wasn't holding a charge either because it's 3 years old and worthless. I got a replacement adapter at best buy for 100 buck and it's universal. Fixed it up just fine and now I'm sharing my solution with you!
Nov 19, 2008 | Gateway 7330GZ Notebook
Dissassemble a gateway 7330 gz
well power button on the plastic or the real power button on the board??? have ya taken out the top plate off over the power button???
Nov 15, 2008 | Gateway 7330GZ Notebook
Power Led Problems
You need to change the battery
Mar 06, 2008 | Gateway 7330GZ Notebook
Gateway (SL1450-30151382) PC Notebook Logo
87 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
