Question about Refrigerators
Kenmore refrig. 13 yrs old. frost in back of freezer, compressor not kicking on. some cold air, but won't keep food cold enough model: 9552710
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side refrig. and the freezer side keeps getting full of frost, and the refrig. side is barely cold, and keeps spoiling food. I've had a tech come out and check things out and...
Either your defrost element or timer is bad or your fridge is low on freon. Frost is a sign of outside air getting in but it can also be a sign of the defrost heating element not kicking in and the defrost timer turns it on for a few minutes each day and a defrost limit keeps it from getting two warm during the defrost cycle. good luck hope this helps
Aug 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
Frige not cold
check in the freezer back wall for frost might be defrost problem or if it has a thermistor it might not be working opening is your freezer 0 or below? 5 year warrant on compressor and sealed system read fine print on papaers if you still have them.may also be in defrost computer board if its a defrost problem
Sep 17, 2008 | Refrigerators
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
