Question about Samtron MONO TTL 13 Monitor
Samtron 4bi display problem
I had to reload my XP due to disk crash. Susequently the display is all konked up and shows only 4 bit colour quality in settings. Please advice what to do
2 Suggested Answers
SOURCE: Sync out Of range
out of rang
Posted on Dec 24, 2009
Can not get xp to reload on to new drive
Check the disk for scratchs and scuffs. It sounds like your disk has been damanged. If you have access to a computer with a CD burner you might try to make a copy of your disk, sometimes even a damanged disk can be copied. If this works, then use the copied disk in the computer to install XP. If not you will need a new XP disk.
Feb 14, 2012 | HP Pavilion 7955 PC Desktop
My PC's color quality shows only lowest 4 bit
Sounds like you need to install a video driver. If you have a video card separate from the mother board, look up the card and download drivers for it. Alternatively, you may be able to use the Windows Update tool to autodetect the driver.
If the video card is on the motherboard, look up the motherboard's model number on the manufacturer's website as they should have drivers there.
Finally, look back at the disks you got with your computer, often there is a "drivers disk" which you can reload the driver with.
Jun 23, 2010 | Intel Celeron M 420 1.6GHz 533MHz 1MB...
After reinstallation of Windows Xp , my display se...
You need to download new video drivers from the computer manufacturer or go to Windows Update and let windows update all your hardware drivers. When windows finishes searching for drivers it will give you the choice of express or custom. Click on custom and look in the left pane. choose Hardware, Oprional. Download and install the selected drivers. Reboot the laptop and reset your video options.
May 21, 2010 | Computers & Internet
In display setting it shows only 4 bit colour. and colour setting is not changing?
Have you installed you mother board and/ or VGA drivers if not do so.
Other wise update your display settings, be it Windows or your screen driver.
Good Luck
Mar 03, 2010 | Microsoft Windows XP Professional With...
Colors in PAINT are limited
assuming you are using XP-
1. right click on your desktop and select "Properties"
2. click on the "Setting" tab
3. make sure that the color Quality is set to "Highest 32 bit"
4. you can also:
  • click on "Advance"
  • find the tab of your graphic card
  • make sure it is on settings that allow high quality of colors
Apr 26, 2009 | Computers & Internet
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Sino gusto funny scandal ust pm i not show start button and messages ,images,system is so slow
when i was chattig witha i got a link when entered the link then i started facing the problem like .how can i get rid of this problem
Apr 10, 2008 | Samtron MONO TTL 13 Monitor
Samtron 95P CRT Monitor
this caused by one or more capacitors on the horizontal circuit
Nov 09, 2007 | SAMTRON 95P 19" CRT Monitor
Computers & Internet Logo
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
