Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore 19 frezer on bottom
Freezer works fine the frig does not
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
Paid 2 people to look at it and still wont work
check air flow at frezer. also were is freezer/frig dial set to? place it in the middle. also look for freezing up on back wall and bottom of freezer. DO NOT SET FREEZER/ FRIG DIAL ALL THE WAY TO FREEZER!!!. PLACE HAND WERE YOU CAN FEEL AIR FLOW AND TURN DIAL AND YOULL SEE WHAT I MEAN.
Feb 20, 2014 | Whirlpool Refrigerators
Kenmore 596.73503201 frig warm, freezer working
Check your duct from freezer section is open if it is check that fan is running ,if it's not the fan is faulty and needs to be replaced
Jan 10, 2014 | Kenmore 73503 Stainless Steel Bottom...
My refrigerater is not cold. but the freezer is working fine. what can be wrong
You have a defrost problem Need model number to see who made your frig as Kenmore makes nothing.
Nov 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
KENMOOR 59672253200
I was out of town and the top part, the refrigerator part lost the coldness. The freezer which is on the bottom is working ;just fine.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
