Question about Rowenta DG-980 Iron
I need a new chrome water stopper that screws onto the drainage hole at the side, where can i get this
    Scholar:
  • 70 Answers
I am in California, so I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Posted on Jul 11, 2008
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER PRODUCES STEAM. WHAT MIGHT BE WRONG AND HOW CAN I ATTEMPT TO FIX IT?
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
Dec 04, 2010 | Rowenta Commercial Garment Steamer - White
Panaonic NI-R73NR Iron suddenly stopped working. Uses a small PCB with OEG PCD-124D2M relay which produces a sound when shaken as if some metal item is moving inside. Can this PCB be entirely replaced? Is...
Okay, here's what fixed mine. But first, understand this is a $23 iron and it may not be worth your effort. I'm an engineer and like fixing things, and I hate throwing stuff into the landfill, so I took the time to repair mine. If you can use a screwdriver and are good at taking things apart (and putting them back together) this will take less than an hour. NOTE: I often make use of a digital camera while taking things apart. Take a picture of things as you go, so you can see how to put them back together later.
The problem is the switch is corroded, from oxidation or carbon buildup, or both. Getting to it is most of the trouble. Follow these instructions:
1. Unplug the iron (helpful hint for the simple-minded. Can't iron if you're dead.) Dump out any water that's in it.
2. Remove two phillips-head screws from bottom of cord winder at base of iron.
3. Pull cord winder housing away from iron to expose electrical wiring.
4. Remove the small gray insulator card from it's slot to expose the screws that attach all the wires.
5. A red, blue, and black wire go up into the handle and attach to the shut-off circuit board. Tug on them gently to slide the circuit board out of the handle, remembering which side is up.
6. There's a screw inside the handle. Look where the circuit card came out and you'll see it in there. Use a screwdriver to remove it. Now you can lift up on the back of the small curved cover where the steam and squirt buttons are, and it will come off. Don't lose the steam setting button, it may fall off.
7. Now you can see the water jet nozzle. Lift it out of the way to find a screw under there. Take that screw out. I call this screw #1 for a reason.
8. There are three screws in the back of the iron, near the wires. They hold the iron together. Left and right are like screw #1. Take them out. The other one is a machine screw that's in the center, going down into the base. Take it out.
9. You can now lift the plastic part of the iron up off the metal part and set it aside. On top of the black plastic where screw #1 went through, near the pointy end of the iron, there should be a small washer. Locate it and set it aside. You'll want to make sure it gets back where it belongs when you reassemble.
10. There is a lamp that turns on when the iron is heating. It has two fine bare wires, a copper one (on the right if the iron is lying flat and you're looking at the base), and a silver one to the left. Find the screw where the silver one attaches and loosen that screw. Gently pull that wire off the screw. Note the routing of that silver wire around the black plastic, including where the tube insulator on the wire lays-- you will need to put this back right later. Lift the lamp out and the silver wire so it's more or less sticking up in line with the screw where the copper wire attaches. This will facilitate the next step.
11. Separate the black plastic cover from the brass-colored metal iron base by lifting at the pointy end of the iron. The wires will try to hang you up in the back, but if you wiggle things just right you'll be able to get them mostly separated. The lamp will need to descend down through the black plastic where the wires go as you lift the plastic cover off. As you lift it off, look inside. You can see where the rotary switch is inside there.
12. So here's the deal: the rotary switch controls a thermostatic set of contacts. This means there's metal in there that bends as it gets hot; the hotter, the more it bends. This controls your iron's temperature. When it bends enough, it opens a set of "points", which are tiny cylindrical contacts at the bottom of the rotary switch mechanism. Put on your glasses and look under the mechanism as you rotate the rotary control and you'll see them click open and closed. You need to clean them.
13. Get a small strip of fine sandpaper (400 grit or finer), about 1/4" wide and 2" long. Turn the control until the points are open and slip the sandpaper in between them. Now turn the switch the other way to get the points to close on the sandpaper. Pull the sandpaper back and forth between the points; that'll clean the contact on the gritty side of the paper. Now open the points again, pull the sandpaper out, flip it over, put it back in, and close the points. Now another few pulls on the paper to clean the other contact.
14.Remove the sandpaper. Put the iron back together in reverse order. Some things to watch out for: When you put the black plastic part back down onto the metal iron base, you'll need to make sure the wires and the lamp go the right way. You also need to make sure that the grey rubber grommet that lets water from the plastic tank down into the heated elements is properly pushed up through the hole in the black plastic. If you have trouble seating the black plastic onto the metal iron base, it's probably because that grommet is stuck halfway through the hole. Make sure you put the steam selector button back where it goes before you put the curved cover onto the top of the plastic tank. Getting the screw up through the hollow handle and into the hole it goes into can be tricky. I held the phillips screwdriver point-up and set the screw on top. Then I held the iron point-up and slowly put the screw up through the handle and into the hole. This might take a couple of tries; be patient-- you'll get it. Be sure to put the circuit card back into the handle the right way. Finally, be VERY SURE to route the lamp wires through the plastic parts correctly, and also make sure that you have correctly routed the red, blue, and black wires from the circuit card correctly before you re-install the cord winder housing.
Nov 22, 2010 | Panasonic NI-R73NR Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Water spray not working
I got a thin needle and gently made a hole through the centre of the nozzle - where the water would usually come out. That cleaned the scum build up out of it and it's working fine again. My nozzle does seem to look like its going into the iron but perhaps it's to get the correct angle of spray onto the clothes.
Feb 13, 2010 | Sunbeam Irons
Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Nov 01, 2009 | Tefal Irons
Morphy richards comfigrip 40715 how to disassemble?
Phil - I have the same problem. Can't see how to dismantle it at all. Did you ever get a solution?
Thanks
Chris
Aug 08, 2009 | Black & Decker AS975 Iron
Steam press
Try sew4less.com--has tank & hose for about $16.00. I'm looking for a water tank cap for the same model if you have a source--Thanks
Apr 26, 2009 | Singer CSP1 Iron
Rowenta DG-980 Iron Logo
99 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
