Question about XRS 9330 Radar Detector
What do the radar codes mean? X1,K1,K2 etc - XRS 9330 Radar Detector
  • 667 Answers
Hi bb360 - X1, K1, K2 etc indicate the radar band the police are using and the signal strength you are receiving. For instance, if you were to see a X5 come up on your display it would mean the guy is right on top of you and it may be too late to slow down. In case you don't have a manual I've included a link for you. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.cobra.com/downloads/manuals/XRS9330_MANL.pdf
Jeff
Posted on Jul 06, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
What does k2,*p7,k3*k1.mean
Ru stitching or knitting something? more information on the plan, PLEASE!
Oct 19, 2014 | Sewing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Codes p171 and p0174 on a chevy truck?
Subject: 97-05 Vehicles with 4.8 5.3 5.7 and 6.0 Gen III V8 Engines and Misfires on One Bank - kw CEL diagnostics driveability DTC P0171 P0172 P0174 P0175 P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 #PIP3056 - (07/12/2004)
Models: (00-05 Cadillac Escalade - C6 and K6) and (02-05 Chevrolet Avalanche - C1, C2 K1 and K2) and (99-05 Chevrolet Silverado - C1, C2 K1 and K2) and (00-05 Chevrolet Suburban - C1, C2, K1 and K2) and (00-05 Chevrolet Tahoe - C1 and K1) and (99-05 GMC Sierra C1, C2 K1 and K2) and (00-05 GMC Yukon - C1, C2, K1 and K2) and (03-05 Chevrolet Express G1, G2, G3, H1, H2 ) and (03-05 GMC Savana G1, G2, G3, H1, H2 ) and (04-05 Buick Rainier S1, T1 ) and (03-05 Chevrolet Trail Blazer EXT S1, T1 ) and (03-05 GMC Envoy XL XUV S1, T1 ) and (03-05 Hummer H2) and (04-05 Cadillac CTS-V DB) and (98-02 Chevrolet Camaro FB) and (97-04 Chevrolet Corvette YB) and (98-02 Pontiac Firebird FB) and (04-05 Pontiac GTO VB)
The following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Check Engine Light with a P0300 due to 2 - 4 cylinders misfiring on the same bank of the engine. DTCs P0171, P0172, P0174 or P0175 may also set for the misfiring bank.
Recommendation/Instructions:
If the published misfire diagnostic does not isolate the cause, perform the following suggestions as necessary:
  • Perform a fuel injector balance test for all 8 cylinders. If a fuel injector concern exists, it is possible to misfuel an entire bank of the engine, causing multiple cylinders on the same bank to misfire even though the root cause is a single fuel injector.
  • Inspect O2 sensor connections on the misfiring bank for corrosion or water intrusion. If water intrusion is found on the right bank, it may be due to the AC Evaporator Condensation dripping onto the O2 sensor harness. If this condition is found, reposition and shield the harness to prevent a repeat concern and repair the connections.
  • Check for excessive exhaust backpressure using the restricted exhaust diagnosis.
  • Swap the Position 1 O2 sensors side to side to see if the misfires move to the other bank of the engine. If so, replace the O2 sensor.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
NOTE: GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition.
Sep 30, 2009 | 2000 Chevrolet Silverado 1500
Radar detector codes
When any detector "detects" radar, it will produce some form of Audiable sound. If someone is speeding, they need to slow down IMMEDIATELY if they want to avoid a ticket. It doesnt really matter if the radar gun is x, k, ka, ku, etc. You will probably get a ticket if you dont slow down.
Most dectectors will have indicators lights or displays that indicate the x, k, ka, etc., radar signals are actually being detected. This can provide SOME useful information. THe letters simply designate BANDS of frequencies that are used to send the radar beams. It is similar to changing the channel on a radio - k and ka bands use HIGHER frequencies for their radar signals.
X band is the oldest radar band and it is used for police radars AND door openers at supermarkets and other locations. If you drive by a supermarket, your radar detector is likely to go off and it is almost certainly going to be X band. CHeck it out next time you drive by a supermarket with an automatic door opener.
Since the police and the radar companies like to play cat and mouse, newer radar bands have been invented that OBSOLETE the older radar detectors. When the K bands showed up in the police radar guns, the radar detector folks had to have a new product offering that would detect X band and K band. And the race continues to go on even today and now, there are LASER police speed detectors and the new "RADAR" detectors now need LASER detectors as well. If you want to know the exact frequencies of these "bands" (K, Ka, etc), let me know and I will send them to you. But they are operating in the tens of GigaHertz regions.
THX
r
Aug 28, 2009 | XRS 9330 Radar Detector
Hey what does k1, ka, x, v s mean, it doesnt say it in our manual
http://www.autoanything.com/radar-detectors/52A17.aspx
Jun 10, 2009 | XRS 9440 Radar Detector
Application to unlock a motorole krzr k2 AT&T cellphone
You need an unlock code you can google for sites that offer them for a small fee or search for someone in your area with a Smart-Clip
Mar 16, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Codes
"K" IS LOCAL POLICE BAND, "KA" IS STATE TROOPER, AND "X" IS SILENT ELECTRONIC ALARM SYSTEMS. HAVEN'T FIGURED OUT WHAT "VA-2 ALERT" IS YET.
OTISRAYSR
Jun 16, 2008 | XRS-757 Radar Detector
Cobra 757 codes
X stands for wide band radars(easy to detect,lots of false alarms)
K/Ka stands for pulse band radars(similar signal has auto doors)
W,L stands for laser detection (very little false signals)
Ku stands for signal most used on speed cameras
V stands for radar detectors detector
Have in mind that you can only lower your speed 20-30 km/h in city zones, and up to 50 km/h on highway.This depends on car,brakes and You.
Cobra laser 360 11 band
Assuming the model number is COBRA XRS 9500CS 11-BAND RADAR/360*
LASER DETECTOR WITH DIGVIEW DATA DISPLAY
& VOICE ALERT
This is what we can find out about it.
DETECTS 5 RADAR SIGNALS: XBAND, KBAND, KA SUPERWIDE, VG-2 RADAR DETECTOR-DETECTOR, SPECTRE 1 RADAR DETECTOR-DETECTOR
DETECTS 4 LASER SIGNALS: LTI 20-20 LASER, ULTRA LYTE LASER, PROLASER, PROLASER III
2 SAFETY SYSTEMS: SAFTETY ALERT & STROBE ALERTS DIGVIEW DATA DISPLAY & VOICE ALERTS
http://www.fixya.com/support/p237601-cobra_xrs_9500cs_radar_detector/manual-313
I again assume the above model number......
Hope this helped some...
Kevin
Mar 24, 2008 | Radio Communications
XRS 9330 Radar Detector Logo
2,704 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
