Question about Vacuums
Possible broken belt..brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=748077
Generic problem for all Vacuums
Possible broken belt. Brush doesn't turn
Posted by Helene on Jul 06, 2008
Possible broken belt. Brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Sanyo factory phone # and or your local vacuum cleaner dealer for the belts. But the owner’s manual you would have to contact the Sanyo factory @ the phone number provided below. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://us.sanyo.com/appliances/vacuum_cleaners/
Customer Service – Go to the Contact Us page and fill out the email request
The Service Center Cust Serv Line 1-800-421-5013
Monday thru Friday 7:30 AM to 5:00 PM (PST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 07, 2008
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
Brush doesn't move
Your belt is broken and needs to be replaced. Turn this brush side up. Unscrew the cover plate and you will see where the belt goes. Pull out roller, put on new belt, put back together and there you go.
Oct 07, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
The brush doesn't rotate on the turbo tool. the belt on it isn't broken it just seems really stiff to turn by hand as well
The belt doesn't have to be broken to be bad. Even if it is stretched or worn it will not turn the brush roll properly. Here is the belt you need and the manual which has instructions:
Dirt Devil Vision Turbo Belts
Download the Manual (PDF)
Dec 21, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
The brush doesn't turn when the machine is running
Hello. Here are some possibilities:
1. Your belt is broken
2. your roller brush end bearings are bound by hair or string.
3. Or both!
Unplug the vacuum, flip it upside down, manually turn the roller, is there resistance? If not, the belt is broken, and the roller is okay.
Nov 15, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Vacuums Logo
188 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
