Question about Eureka 2576A Steam Vacuum
Suction Cover The suction cover of my Eureka Deep Steam 2575A is broken - the tabs snapped off of the cover so I am unable to screw the suction cover back on. I need to purchase a new suction cover but can't find one anywhere. Anyone know what I can do? thanks
If my sprayer is plugged lint? cat hair?then how do I unplug it? I still haven't figured out how the squeeze trigger works. Can't see how it can contact the sprayer.
There is a clear cover over the suction head that is held on with 2 screws. Remove the screws with a philips screw driver and the cover will remove providing access for cleaning. Refer to your owners manual which provides this info with a photo I think. Reinstall in the reverse manner. Be careful not to over tighten the screws as you could strip the threads. So to reassemble do not use an electric screw driver or drill type screw drive.
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka Atlantis Rug shampooer wont **** up the water, how can I fix it. Thanks Dennee
make sure that the two slide-tabs on the front of the machine are all the way down so that they can hold the front see-through cover down and create suction at the front. I did the same thing. you can tell when they get moved while cleaning because you will hear a muffled pop like something just got sucked into the vacuum. It is just the sound of suction being broken.
Jul 17, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Low suction with Eureka Whirlwind 4481 Upright
Most times it is plugged at the inlet. There 2 screw on top, one on each side, in one of the holes or slots. Take top cover off, then check that inlet and hose to see if it is clogged there or not, you might replace the belt while you have cover off, part# 54312. I am sure it is stretched if it hasn't been replaced in a while. If the hose is clogged, the you will have to take off the handle, then the hose can be taken off so you can clear any clog in it.
Jan 24, 2008 | Eureka Whirlwind 4481 Upright Vacuum
Eureka deep steam cleaner
When these stop picking up water, I assume it is spraying the water out, is because of a missing seal, where the suction port is, or a filter is clogged. Tank isn't set down like it should be.
Jan 02, 2008 | Vacuums
How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Dec 27, 2007 | Eureka WhirlWind 4381 Upright Vacuum
Eureka vacuum
if you have ran over any big objects you might try removing the cover from bottom take out the roller brush and see if it is clogged from the bottom
Nov 30, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 2576A Steam Vacuum Logo
191 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
