Question about Lanzar VIBE266 Car Audio Amplifier
Prot. light at High vol. (forget Bass CD)
2001 Ford Ranger extra cab.
I have a LanzarVIBE266 4000w. amp running two Boss 12s 1200w ea.
4ga. power/ground cables. 150amp. inline block fuse.
ground less than 2' grounded to bare metal (where rear jump seat is bolted to frame).
My amp's protection light comes on within sec. of turning up vol. (only cd not fm radio) Protect light will stay on until I turn off and back on deck. New Pioneer deck DEH-P6000UB. yes hooked up correctly...New deck or old deck never been able to listen to any of my bass cd's.
Old deck went into prot. mode only when Bass cd used. + new deck does have more power. than old Panisonic Still verry good working deck.
I just wanted Super tunerIII again. :)
What could it be?
just for double checking I called Pioneer Tech dept. and was reasured that it is absolutly not deck/deck wiring.
I want to listen to my bass cd's till my ears bleed can some one help me with this issue? Pls.
  • Joshua Richardson Jul 07, 2008
    One Speaker per channel. Speakers are two voice coils per speaker/ only one hooked up per speaker. Speakers are Dual 4ohm.
  • franco_82002 Nov 23, 2008
    My red protection light keep going on!
  • 631 Answers
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Posted on Jul 07, 2008
  • Perry Babin Jul 08, 2008
    Try disconnecting the speaker wires from the terminal block of the amp for one speaker to see if it can be forced to go into protection.
    Then do the same for the other speaker. Does the amp go into protect mode with only one speaker connected at a time?
800w sony amp
I know i had a similar problem in my car, i ended up needing to do a battery relocation to the boot and putting a bigger battery in. Dont forget that just because the physical size is big doesnt mean it it has the amps so read the battery!
Dec 04, 2013 | Kicker KX Series 04KX1200.1 1200w RMS...
What does camshaft position sensor do truck runs fine
it helps milage! thats enough to be worth fixing. its not too high for part, but hard to get to it when replacing.
Sep 18, 2012 | 2001 Ford Ranger Regular Cab
2001 Ranger, XLT, In colder weather, I just get a
statrter selinoid sounds pooched a 20 buck fix
Jan 02, 2010 | 2001 Ford Ranger Regular Cab
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
2001 Ford Ranger Extra Cab windshield wipers don't work. Fuse is intact. Problem occured after dome light removed.
WOW that is strange. Get your self a test light or a cheap multimeter. Take the + wire off at the wiper motor and check if you have voltage / power. If you do then the problem is with the wiper motor if you don't it is the wiring or the switch. I know, not a complete solution but it cuts your problem in half :)
Good Luck
Aug 15, 2009 | 2001 Ford Ranger Regular Cab
Daytime running lights
the light sensor that tells lights when to come on that is located on dash is having problems
Jul 10, 2008 | 2001 Ford Ranger Regular Cab
A/C service valve
IT IS THE VALVE ON THE ACCUMULATOR, THE ONE BY THE RADIATOR IS THE HIGH SIDE LINE
Jun 15, 2008 | 2001 Ford Ranger Regular Cab
Lanzar VIBE266 Car Audio Amplifier Logo
123 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
