Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Leaking frig. Inside my fridge leaks. I see that a lot of people have the same issue. I have pulled everything out of the freezer and tawed the ice out and cleaned it up pretty good. Do I need to open the back of my Kenmore fridge and see if the defroster drain that goes to the drip pan is clogged? My wife wants to buy a new one but I just want to fix the problem. When I defrosted the entire freezer (under the dummy shelf on the bottom of the freezer too) it started leaking again. Help!! Nate
  • n8parry Jul 25, 2008
    This was very helpful. Once I pulled the back panel off the back inside freezer I found the drain hold completely froze up with water. After a couple minutes of using a hair dryer and then pouring hot water down the line it broke free and the hot water made it to the drip pan. Thanks a lot for you help. I guess my next question would be, how do I prevent a freeze up again in the drain line? What caused it to freeze up. Nothing seem to me restricting the water from going to the drip pan other than it be frozen.
    Nate
  • 481 Answers
  • take out the back wall of the freezer and physically clean out the line. you may need to run a coat hanger or something down the drain to unclog it. also pour some hot water down the drain after you think you have it unclogged.
  • the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Posted on Jul 06, 2008
What is wrong when the icemaker leaks into the inside of the fridge
ok unplug frig open freezer door empty ice let freezer door stay open for a few hours ice has formed where the ice cube water comes into it. ice built up and water sprays every where but where it should
Aug 19, 2014 | Refrigerators
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
My fridge keeps leaking water and the inside becomes warm for a few days, everything melts in the freezer. Then it works again. Please help.
HI,REMOVE EVAPORATOR COVER IN THE FREEZER COMPARTMENT AND CHECK THE DRAIN,IF ICE MAKER IS INSTALLED CHECK FOR ICE MAKER LEAKS,
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
Fridge is leaking
IF LEAKING FROM TRAY ON COMPRESSOR THEN IT IS RUSTED THROUGH. IF INSIDE THE FRIG. THE DEFROST DRAIN IS CLOGGED WITHE EITHER ICE , DEBRIS OR GUNK. FIRST TRY DEFROST, BY TURNING OFF OR UNPLUGGING UNTIL ICE IN FREEZER IS COMPLETELY GONE. IF PROBLEM CONTINUES THEN CALL FOR LIVE HELP. COULD BE DEFROST TIMER AND SOME OF THE STOPPAGES ARE BETTER LEFT TO SOMEONE FAMILIAR WITH PROBLEM AND RESOLUTION.
Mar 10, 2010 | Roper Refrigerators
Ice maker is making ice but leaking alot of water under the fridge and in the freezer. What can I do to shut if off until I repair the ice maker?
pull our your frig. and follow the water line coming into it. the other end should have a valve on it in the floor or the wall. turn off the valve and that will stop any water from coming to your frig for water or ice making.
Apr 22, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Frost on bottom of freezer inside refrigerator section, leaking
Hi!!! You have a plugged drain line in your evaporator..For a quick fix just turn off your frig for 24 hours and set your temp control at the factory setting listed on the frig and you will be finw trust me..Good luck..
Jan 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool refrigerator leaks water inside the frig. It gathers in the pan under the lowest sliding drawer. Possibly something to do with the icemaker? I don't use the icemaker -- I flipped up the bar...
Its a done deal...:) On MY whirlpool MODEL # ETICHMXKBO3 I found the drain hole frozen.. There was some debris and clogged it up and water froze up behind it causing the deck of my freezer to fill and freeze up and cause the water to drain into the fridge. Solution: remove the ice maker(if equipped) remove the rear aluminum cover. I used a heat gun and melted the 1 1/2 of ice build up and softly with a screw driver clean the drain. When drain is visible use scolding hot water until it starts flowing to the bottom tray. I used my air compressor to finish it off....
Jun 18, 2008 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
392 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
