Philips 42PF7320A 42 in. Plasma HDTV Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options, but cannot get any of them to function. I think I need to be led through setup from the very beginning.
Anonymous
Level 2:
New Friend:
  • Expert 39 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
39
Questions
0
Helped
9889
Points
107
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
2answers
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
TV Stuck on Video
hit input button u dont have orgibnal remote for tv so go to the tv hit ch down button to u see it chage the inputs to video 2 3 whatever your cable is on dvd ect ok
How to change the inpute setting om my flexvision tv
Should be a button on your remote labeled input or source. If it does not it could have buttons with icons/lettering on them with a tv or spelled out tv, HDMI, input 1...2...etc. If none of these apply it can be done by hitting the Menu button, going to the video section and select input you would like. This can also be done with the menu button on your tv.
DCT700/US - Unable to turn on with remote. Yellow light flashes on then off to brief red light then nothing. Tried removing cables and plugging in to power outlet only, but same result.
it sounds like the box is working proper... just needs to wake up. the remote may be your problem.
God Bless Motorola For Giving Us Cable Boxes With No Buttons!
ok, does your remote have lights that flash when you hit buttons?
for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
good luck
2helpful
White flickering line across top of tv with non HD channels
It appears that when you go back to normal tv from hdtv you are able to see the overscan area. Change the aspect of your image with the appropriate button on your Vizio remote and or cable remote. Apparently the button that changes the aspect on the Vizio remote is the wide button. The cable remotes will usually have hd zoom (#), aspect or format.
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
