Question about Eclipse CD3422 CD Player
Clock How do i change the time on the clock?
  • 3 Answers
1. Press the "func" button for more than 1 sec. 2. Press the "custom" button to switch the clock adjustment mode. 3. Press the "source" button to select the hour or minutes to be adjusted. (The blinking one can be adjusted.) 4. Press the (<BND>) button. (<) button : Turns the time forward. (>) : Turns the time back. 5. Press the "custom" button again to return to he normal mode.
Posted on Aug 03, 2008
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
Setting clock on laptop toshiba need to find out how to change time on laptop pc
Click on the clock time and you can edit the time and date.
The clock time is on the bottom right hand side of the desktop.
Feb 07, 2014 | Toshiba Computers & Internet
Setting time on wincraft desk clock
Directions for Desk Clock - Without the C?/F? button
To change the Temperature:
Press the "S" button once (this will change from Fahrenheit to Celsius)
To change the Time and Date:
Press the "M" button once to change time to or from military time
Press the "S" button once to change the hour
Press the "S" button again to change the minute
Press the "S" button again to change the year
Changing the year will also change the day of the week
Press the "S" again to change the month
Press the "S" again to change the date
To set the Alarm:
Press the button with an alarm clock on it
A flashing 12:00 should appear
Press the arrows to set the hour
Press the "S" button again to set the minutes
Press the "S" button again to change the "ring" of the alarm
There will ne a number below the time the alarm is set for
Use the arrows to advance through the options
To turn the alarm functions completely off:
Press the button with the alarm clock on it
Press the "S" button five times
When three dashes appear where the time would be, it is off.
Press the "M" button three times to get back to the main clock function
To clear the secondary clock:
You can set two different times on the clock, so if you travel frequently you can have a home time with alarm and a travel time with alarm saved and ready to go. There is a primary time, the one you normally see on the clock with an alarm clock function after it. There is also a secondary time with an alarm function after it.
Clearing the secondary clock will make it easier to know when you get back to the primary clock function.
Press the "S" button seven times
Press the "M" button two more times
And you are Done!
Jan 02, 2012 | Wincraft FLORIDA GATORS OFFICIAL THE SWAMP...
How do I change the time one hour ahead for an RP5430A model clock radio?
Slide the Wake 1/Wake2/Clock switch to the Clock position. Then press the forward button to advance the clock by the needed amount of time. Then slide the switch back to the side with the key icon.
If you set the DST switch to ON, you can move the time zone switch to one time zone further east for a few weeks until the DST change in the program takes effect. Then move the time zone switch back to your current time zone. (Repeat this in the fall to correct for the later change in DST again). The exact length of time between when DST starts and ends versus when the clock will change the program will depend on when the clock was manufactured. Clocks built after July 2006 should have the correct DST programs. Clocks from earlier have a much shorter period of DST (April through Oct).
I hope this helps.
Mar 13, 2011 | RCA RP5430 Clock Radio
Power transformer if change from 50 hz to 60 clock
Is that a question or a statement?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-ICF-C212-Clock-Radios-manual/id/267ag023/t/2/
Considering a 9VDC battery keeps the clock alive when power is disconnected, I would guess the clock time is independent of line current frequency. Does anyone actually use motorized clock works anymore?
Feb 19, 2011 | Sony ICF-C212 Clock Radio
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Apr 02, 2010 | Emerson SmartSet CKS1850 Clock Radio
I have a radio Shack Atomic Wall Clock 63-1438 and the time didn't change on Oct 31, 2009. Should it automatically change of do I have to reset the clock?
Most atomic clocks simply receive the National Institute of Standards and Technology (NIST) time signal. They do not all allow for daylight savings time changes as not all areas use it.
You will have to adjust manually.
Nov 04, 2009 | SkyScan 86709 Atomic Wall Clock
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Daylight savings time again
Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
Eclipse CD3422 CD Player Logo
97 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
