posted by brent00 on Jul 06, 2008
rca d52w19b turns off after being turned on
1 Other User Has The Same Problem
Comment by davef51, posted on Aug 20, 2008
the tv would turn off then on by itself, the led didn't blink, it would just go on and off with the set. now the set sizzles when turned on then goes off by itself after about 5 sec
Solution #1
posted on Jul 06, 2008
does it continue to turn off then on by itself? Does the led flash if you try to power it back on again when it shuts off. If so how many times does it blink? Please respond to this same post when responding.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Panasonic PT-52LCX65 44 in. HDTV Television
Panasonic PT-51HX41 51 in. Rear Projection Television
Panasonic PT-53WX53 53 in. Rear Projection HDTV-Ready Television
Panasonic PT-51HX42 51 in. Rear Projection Television
Panasonic PT-56WXF95 56 in. Rear Projection Television
Panasonic PT-40LC12 40 in. Rear Projection HDTV Television
Can you Help with these Projection Televisions problems?
Philips 50P8341 50 in. Rear Projection...
Philips 50p8341
Philips 50p8341
hi my problem is this first... Answer This...
Mitsubishi WD-52525 52 in. Rear Projection...
help needed fast
help needed fast
im having a problem with my... Answer This...
norcent pt4240hd screen blacks...
norcent pt4240hd screen blacks... Answer This...
Repair Service
Find Projection TV Repairman Near You:
