Question about Whirlpool RBS305PD Electric Single Oven
Whirlpool RBS305PDB17 not working. Strong electric smell then everything on it stopped working. No display or heat. Breaker is fine.
  • 113 Answers
Check for the power cable's more over i wud suggest not to  unscrew the washing maching and try anything out risk of electric, best u can take it to a professional and have it checked
Posted on Nov 14, 2008
    Champion:
  • 225 Answers
The smell comes from a component burning itself out. A new circuit board will probably be needed.
    President:
  • 2,712 Answers
Looks like an internal short circuit. Best get a professional to check it out.
    Genius:
  • 1,847 Answers
Firstly check the power cable is getting heater or not?
  • Legin Varghese
    Legin Varghese Nov 14, 2008
    if it is getting heated then there should be a short circuit in the power cord itself..
I have a Whirlpool electric acubake wall mounted double oven which is 15 yrs old. Most of the time the digital controls work fine. Twice now the digital display has gone totally dark. An hour or so...
Anonymous, we're sorry to learn that your Oven isn't heating. We will be glad to further review your concerns. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, contact number, address, model and serial number.
Oct 23, 2017 | Whirlpool Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont heat
There is a temperature activated thermostat (TOD) that is located on the back of the oven that would explain the problem you are having. The part can be checked with an ohmmeter and should read 0 resistance if it is good. The part number is 9759243 if your model number in the description is accurate (RBS245PDS)
May 04, 2010 | Whirlpool RBS245PDS Electric Single Oven
No heat! Lights work, timer etc - everything "appears" to be working but there is no heat!
Probably your heating element has failed, dependant on appliance the element can be found in the oven itself at the back behind a panel that normally has a couple of screws holding the panel in place. reasonably easy to fit yourself and not very costly.
Hope this helps
Apr 01, 2010 | Whirlpool RBD305PD Electric Double Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool single electric oven - model unknown
Turn the breaker off that supplies the power to the oven for 5 minutes to allow the computer to reset. If this doesn't work you my have a bad board.
Aug 04, 2008 | Whirlpool Ovens
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBS305PD Electric Single Oven Logo
78 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
