Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Brushes don't go around
I have a problem where the brushes don't go around. Any suggestions?
    Problem Solver:
  • 7 Answers
The power wire may have slipped off inside.
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
Posted on Aug 05, 2009
How do I clean the brush area after using my Pro Heat?
The brush or brushes (depending on your model) can be removed if needed. Routine cleaning should just require removing hair and debris from the brushes and wiping the area around the brushes.
There should actually be very little hair or debris around the brush roll if the carpets are thoroughly vacuumed by a properly working vacuum cleaner before being cleaned.
Jan 22, 2017 | Vacuums
Hi i have a hoover F5853 when the brushes in contact with the carpet they quit spinning but it is on and lift the front up they start spinning but as soon and i put it back down they quit please help
Belt around brush roller is worn, it spins freely when there is no pressure on it. But put it on the floor, the belt won't turn the brushes. I suggest taking unit to vac repair shop for new belt installation
Dec 05, 2014 | Hoover Vacuums
Spinscrub loud brushes don't spin
Most models have a screen under the machine or behind one of the clear covers on the front. If the screen is clogged it will restrict the airflow.
Make sure the brushes will spin freely by hand.
Oct 06, 2017 | Hoover Steam Vac Dual V w/ SpinScrub...
Bissell Proheat brushes don't turn. Belts fine.
Make sure the brushes are not seized or restricted
Aug 27, 2017 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Brushes dyson
If you are talking about the beater bar brushes. I replaced mine and had to order them online , also there is a transmission they call it which is like a clutch on a cordless drill, where it will ratchet or skip when it binds up, My problem was the beater bar brushes were wore down. to change this remove plastic bottom cover and then work the bar out (this stretches the belt ) so it takes some strength to get it out, I would suggest replacing the belt also if you are doing this,I also ordered it with the brush bar at same time. If it's the motor (electric) brushes you are talking about , I have not encountered a problem with those yet. I hope this helps you out and don;t forget to rate it thumbs up ! thanks
Dec 17, 2011 | Dyson DC27 Bagless Upright Vacuum
I have a 550 that will not **** it drives around and thinks its doing a great job but does not pick up any dirt does anyone know what the problem is or where I can get it fixed ?
Have you cleaned out the dirt compartment? This compartment is very small and fills fast ... Roomba does not have a vacuum in it ... it just sweeps so make sure the brushes are working and in good order ... to test the brushes hold it up and turn it on make sure your fingers are clear of wheels and moving brushes before turning it on. Visually inspect to see if brushes are turning also check for hair and string around wheels and brushes.
dont forget to rate me Thx :) and good luck
Sep 30, 2009 | Roomba Vacuums
Bissell Shampooer, The brushes will not stay up so can,t push it.
Did this start happening after you removed the clear side pieces, to clean around the brushes? You may have loosened or removed the black plastic arms that hold the brushes in place off the floor. One goes on each side, and is mounted to the Bissell with a silver screw with a built in washer. The brushes fit inside these two arms, and they are also held in position by the black belts. The big one goes around both brushes on the left side as I face the machine. The small one goes around the back brush and a small cog on the right side, as I face the Bissell.
Nov 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Beater brushes wont work
Sounds like you really need a new belt. Don't know why it is taking so long for you to get one. But belts stretch and then won't turn the brush roll under load. Call around to your local repair shops, must will a good selection of belts on hand.
Mar 12, 2008 | Vacuums
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
